General Case of Relative Velocities
  • Thread starter Thread starter Quarlep
    General Relative
The discussion centers on the general case of relative velocities in the context of relativity, specifically addressing the formula for velocity addition as presented on Wikipedia. Participants noted a potential typo in the formula, where two velocity vectors, ##\vec{v}_A## and ##\vec{v}_B##, are shown side by side in the denominator without a dot product indicated. It was confirmed that ##\vec{v}_{BA}## represents the velocity of B in the rest frame of A, necessitating the calculation of this vector based on known velocities.
  • Understanding of vector mathematics
  • Familiarity with the principles of relativity
  • Knowledge of dot products in physics
  • Basic comprehension of velocity concepts
  • Review the Wikipedia article on relative velocity for detailed examples
  • Study the mathematical derivation of velocity addition in special relativity
  • Learn about vector operations, specifically dot products and their applications
  • Explore case studies involving relative velocities in different inertial frames
Physics students, educators, and anyone interested in the mathematical foundations of relativity and vector analysis will benefit from this discussion.
Quarlep
I was looking relative velocities and I saw General case in Relativity part.That part means every direction isn't it.
http://en.wikipedia.org/wiki/Relative_velocity
and in there B is the observer or A is the observer
Thanks
Thanks
With respect to the general case of velocity addition in the wiki, there appears to be a (typo) in the formula.
I see two vectors (velocity A and velocity B) side by side in the denominator of the fraction. Most likely this is a dot product but there is no dot between them.
Yes? No?
##\vec{v}_{BA}## is the velocity of B in the rest frame of A, which needs to be calculated; ##\vec{v}_A## and ##\vec{v}_B## are the velocities of A and B in some other frame, which are presumed to be known at the start of the calculation.
Yes, there should be a dot between them.
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 17 ·
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 36 ·
