General rule for a confusing series
2 replies · 2K views
Jesseac
Hi,
I am a year 12 IB maths HL student... and i was wondering about the possibility of a general rule for a particular problem... I was looking at the following rules, which came up in a basic textbook exercise on mathematical induction.
1+2+3+4+...+n=(n^2+n)/2 where n is a positive integer
(1^2)+(2^2)+...+(n^2)=(n(n+1)(2n+1))/6, where n is a positive integer
I was wondering if there exists a rule for the case.
(1^a)+(2^a)+(3^a)+(4^a)+...+(n^a), where both n and a are positive integers.
This problem has been bugging me for quite some time. I had the feeling that the problem may be slightly different for odd values of a as opposed to even values of a.
Also, if there does indeed exist a general rule or rules for this case, I was wondering if someone could give an outline as to the method used to prove this (as I'm not so confident in attempting it for myself).
yes it exists in terms of the Hurwitz zeta function or Bernoulli Polynomials
if 'm' is an integer
[tex]1+2^{m}+...+k^{m} = \frac{B_{m+1}(k)-B_{m+1}(0)}{m+1}[/tex]
otherwise you need the Hurwitz zeta function.. look at this at wikipedia.
I don't know a general rule for discovering formulas for sums, but proving they work is often straightforward. If you think that [tex]\sum_{i=0}^n a_i = G(n)[/tex]
then see if you can write [tex]G(n)[/tex] as [tex]F(n+1) - F(0)[/tex] for some [tex]F(n)[/tex] with the property that [tex]\triangle F(n) = F(n+1) - F(n) = a_n[/tex].
If you can do that, you're done, since for such a [tex]F(n)[/tex],
[tex]\sum_{i=0}^n a_n = \sum_{i=0}^n (F(n+1)-F(n))[/tex]
[tex]=(F[1] - F[0]) + (F[2] - F[1] ) + (F(3) - F(2)) + ... (F(n+1) - F(n) )[/tex]
which "telescopes" to [tex]F(n+1) - F(0)[/tex]
Example: [tex]a_n = n[/tex]
[tex]G(n) = \frac{(n)(n+1)}{2}[/tex]
[tex]F(n) = \frac{(n-1)(n)}{2}[/tex]
[tex]\triangle F(n) = \frac{(n)(n+1)}{2} - \frac{(n-1)(n)}{2}[/tex]
[tex]= \frac{n^2 + n}{2} - \frac{n^2 - n }{2} = n = a_n[/tex]
You can also invent summation formulas for complicated looking sequences by setting [tex]F(n)[/tex] equal to some formula and working backwards to the series that it sums.
