General Solution for y'' + 6y' + 8y = 2t + et
11 replies · 2K views · last reply
cse63146
Compute the general solution of y'' + 6y' + 8y = 2t + et
after using determinants, I found the general solution to be y(t) = k1e-2 + k2e-4 + yp
To find yp, I would make it equal to yp = aet find its first and second derivates, and substitute them back into y'' + 6y' + 8y , but what do I do about the 2t?
You can do some clever guess work. You can make sure that y'' is 0 by taking some linear function. This simplifies your problem to 6y'+8y=2t. Since we took a linear function y' will be a constant so this will reduce your problem to constant+8y=2t. A function of the form b+ct should suffice.
would yp = t be a good guess?
since y'p = 1 and y''p = 0
But [itex]6+8t \neq 2t[/itex], so no. Try b+ct as suggested in my previous post.
how about [tex]\frac{1}{4}t - \frac{3}{16}[/tex]
so 6(1/4) + 8([tex]\frac{1}{4}t - \frac{3}{16}[/tex]) = 3/2 + 2t - 3/2 = 2t
so when considering et, I would let yp =[tex]\frac{1}{4}t - \frac{3}{16} + e^t[/tex] ?
The linear term is correct now, however if we plug in e^t we get, e^t+6e^t+8e^t=15e^t!=e^t. So you have to divide by 15.
oops
it should be [tex]\frac{1}{4}t - \frac{3}{16} + ae^t[/tex]
and a would be 1/15
Pretty sure you meant to write y(t) = k1e-2t + k2e-4t + yp here.
