General solution of a system of equations and partial fractions
The discussion focuses on solving a system of equations and expressing a rational function in partial fractions. The first part confirms that (1,1,1) is a solution to the equations, and the general solution can be expressed as (x,y,z) = λ(1,0,-1) + μ(0,1,-1) + (1,1,1). The second part involves expressing the function 2x^2 + 3/(x^2 + 1)^2 in partial fractions, where the user initially attempted a matrix method but was advised to use repeated factors instead. The correct approach involves expanding and equating coefficients for each power of x after substituting values. The user seeks further clarification and assistance on both parts of the problem.
phy$x
I've been trying to get out this question for a while now:
ai) Show that (x,y,z) = (1,1,1) is a solution to the following system of equations:
x + y + z = 3
2x + 2y + 2z = 6
3x + 3y +3z = 9
aii) Hence find the general solution of the system
b) Express 2x^2 + 3/(x^2 + 1)^2 in partial fractions
My attempt:
Well ai) was simple and i got that part out with barely any effort.
In aii), i don't even know how to start :( All i know is that the answer is supposed to be:
(x,y,x) = λ(1,0,-1) + μ(0,1,-1) + (1,1,1,)
Sorry i can't offer any attempt...i just really don't know where to start...any help at all will be appreciated here.
With b) i used the matrix method...but that wasnt the approach they were looking for. I was supposed to use the concept of repeated factors:
2x^2 + 3/(x^2 + 1)^2 = Ax + B/x^2 + 1 + CX + D/(x^2+1)^2
(multiply throughout by (x^2 + 1)^2)
2x^2 +3 = (Ax + B)(x^2 + 1) + Cx + D
Let x=0
3 = B + D
D = 3 - B
Let x= 1
5 = (A + B)(2) + C + D
5 = 2A + 2B + C + D
Substituting D = 3 - B
5 = 2A + 2B + C + 3 - B
2 = 2A + B + C
Well this is where I am stuck...any help at all would be a life saver. Thank you in advance.
Strange question. Clearly all three equations are equivalent, so we can ignore the 2nd and 3rd.
Since x+y+z is linear, having found a solution of x+y+z=3, we can add to it any solution of x+y+z=0 and the result will be a solution of the original equation. So the question is essentially asking you to find all solutions of x+y+z=0.
Seems you mean (2x2 + 3)/(x2 + 1)2. Please use parentheses properly and subscript/superscript. Makes expressions much more readable.
The usual procedure from this point is to separate out each power of x into a different equation. That will give you four equations here.
x + y + z = 3
2x + 2y + 2z = 6
3x + 3y +3z = 9
My attempt:
Let x=0
3 = B + D
D = 3 - B
Let x= 1
5 = 2A + 2B + C + D
2 = 2A + B + C
In (b), do you mean
2x^2 + \frac{3}{(x^2+1)^2} (which is what you wrote), or do you mean
\frac{2x^2 + 3}{(x^2 + 1)^2)}?
If you meant the former, then what you wrote is perfectly OK, but if you mean the latter, you must use parentheses, like this: (2x^2 + 3)/(x^2+1)^2. Using ASCII and hence things like x^2 is OK, but you must write clearly. Also, where you write
Ax + B/x^2 + 1 + CX + D/(x^2+1)^2, you are writing
A x + \frac{B}{x^2} + 1 + Cx + \frac{D}{(x^2+1)^2}.
I hope that is not what you really mean, but again, without parentheses, your expressions are impossible to parse (and, frankly, it takes too much of my time, so I won't even try).
i meant:
(Ax + B)/(x^2 + 1) + (Cx + D)/((x^2 + 1)^2)
Sry about that...
My attempt:
With b) i used the matrix method...but that wasn't the approach they were looking for. I was supposed to use the concept of repeated factors:
Let x=0
3 = B + D
D = 3 - B
Let x= 1
5 = 2A + 2B + C + D
2 = 2A + B + C
Well this is where I'm stuck...any help at all would be a life saver. Thank you in advance.
Expanding the product and collecting terms in the equation
2x2 +3 = (Ax + B)(x2 + 1) + Cx + D
gives
\displaystyle 2x^2+3=Ax^3+Bx^2+(A+C)x+(B+D)\ .
Now equate coefficients of each power of x.
Thanks a lot guys! All help greatly appreciated. :)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
