General solution of ode using fourier transform
7 replies · 13K views
naspek
ok well I'm pretty much home and dry in this problem
the aim of this problem is to get the general solution for the ode below..
2u'' - xu' + u = 0 = g(x)
i started to solve it by rearranging the equation..
2u'' + u = xu'
apply Fourier transform..
2F(u'') + u^ = g^
(-2k^2)u^ + u^ = g^
u^ [1- 2(k^2)] = g^
u^ = {1/ [1- 2(k^2)]}g^
the problem is, i can't find any of the them in the transform table..
So g(x)=0?
2u'' + u = xu'
2F(u'') + u^ = g^
Where did the xu' term go, and where did g come from?
(-2k^2)u^ + u^ = g^
u^ [1- 2(k^2)] = g^
rearranging my equations...
2u'' + u = xu' = g(x)
where xu' = g(x)
F{ 2u'' + u = g(x) }
-2k^2(u^) + (u^) = (g^)
(1 - k^2 )(u^) = (g^)
u^ = [1 / (1 - k^2 )] (g^)
correct?
Sort of, but it's not what you want to do. What exactly is g(x) supposed to be? According to your first equation (in your original post), g(x)=0. Or is it supposed to be the source term/forcing function, i.e. the term that results in the particular solution?
Try looking up a property of the Fourier transform relating [itex]xf(x)[/itex] to [tex]\frac{d}{dk}\hat{f}(k)[/tex].
xu' --->> [- (1/ i2pi)][d/dx]u
correct?
should i substitute it to my previous equation?
Try it out.
vela said:
Try it out.
F(u'' -xu' + u = 0)
F(-xu') = -[(-1 / i2pi)(d/dx)u^])
F(-xu') = [(1 / i2pi)(d/dx)u^])
F(u'' -xu' + u = 0)
[1 -2k^2 + (1 / i2pi)(d/dx)]u^ = 0
correct?
naspek said:
F(u'' -xu' + u = 0)
F(u'' -xu' + u = 0)
correct?
No, you seem to be missing a factor of k. First, take care of the effect of the x:
[tex]F[xu']=\frac{1}{-i}\frac{d}{dk}F[u'][/tex]
And then take the Fourier transform of u':
[tex]F[xu']=\frac{1}{-i}\frac{d}{dk}(-ikF<u>)=\frac{d}{dk}[k\hat{u}(k)]</u>[/tex]
(If you're using x and k, I think there are no factors of 2π.)
