General Solution to the Diff. Eq. dy/dt = ty
The discussion revolves around finding the general solution to the differential equation dy/dt = ty. Participants explore the integration process and the steps involved in solving the equation, with some expressing confusion about the integration of variables and the introduction of constants.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the initial step of separating variables and integrating both sides. Some express uncertainty about the correct form of integration and the introduction of constants in the solution. Others question the separability of different forms of differential equations presented.
The discussion is active, with various interpretations and approaches being explored. Some participants provide guidance on integration techniques and the concept of separable differential equations, while others seek clarification on specific steps and reasoning.
Participants mention the importance of understanding integration and algebraic manipulation in the context of differential equations. There is a recognition of the challenges posed by different forms of equations and the need for clarity in separating variables.
the7joker7
Find the general solution of the differential equation specified.
\frac{dy}{dt} = ty.
I already know the answer to be ke^{t^{2}/2}, but can't figure out how it got here. I'm rusty with my integrals and am just really starting diff eqs, but I think I'm just supposed to take the integral of ty (which is (t^2y)/2 i believe) and add a + c to the end, c being some constant, so I'm confused...
I think this might be a logical first step: dy/y = t dt. Now integrate that.
dy/y = t dt
The integral of that would be...
dy = t^2/2
So
(t^2/2)/dt = ty
t^2/2 = ty dt
Where do I go from here?
No. You might want to brush up on your integrals. The integral of dy/y is not dy but rather log(y). Therefore, your equation should be?
log(y) = t^2/2
So y = e^(t^2/2)
Alright. And the k is because it's a general equation and k needs to be there so it can be solved for any initial condition. But why is the k being multiplied and not added?
Well, the equation should read: log(y) = t^2/2 + C; therefore, y = e^(t^2/2 + C) = e^(t^2/2)e^C. We let e^C = k and the equation reads: y = ke^(t^2/2)
Just to be sure, is the basic starting step for all problems of this type getting dy/y?
Like if I have the same question with dy/dt = t/(t^2y + y), I would try to get dy/y on one side?
The basic goal is to get y and dy on one side, and t and dt on the other, which is called separation. Your example differential equation is not separable, if I understand what you wrote. Is the first term in the denominator t^(2y) or is it t^2 * y? If it's the first, your example isn't separable.
Oops, my bad. It's the 2nd one.
dy/dt = t/((t^2)y + y)
Lesse
dy/y = t/((t^2)y^2 + y^2) dt
dy/y * y^2 + y^2 = t/(t^2) dt
dy/y * 2(y^2) = 1/t
ln(y) * 2(y^3/3) = 1/t
Ugh...I dunno, something in that ballpark? I'm confused...
I don't believe that's quite right. Your initial equation is: dy/dt = t/(y(t^2 + 1) correct? Then we claim that y dy = (t dt)/(t^2 + 1) which we then integrate.
These are called SEPARABLE DEs. Separable because we can separate them into f(y) dy = g(t) dt. And then integrate both sides. This is also why DE requires you to do well in Calculus classes so you don't have to think about how to integrate :) This is also why separable DEs are introduced in Calc 2(I guess), to give you a flavor of what to come.
y^2/2 = (t dt/t^2) + t dt (If I understand correctly, this is separating?)
y^2/2 = ((t^2)/2)/t^2 + t^2/2
y^2/2 = 1/2 + t^2/2
y^2 = 1/4 + t^2/4
y = sqrt(k(.25 + t^2/4))
Eh?
No the separating was the process of writing dy/dt = g(t)/f(y) as f(y) dy = g(t) dt.
a/(b+c) is definitely not a/b + a/c, you should remember that from algebra.
You should know how to integrate t dt/(t^2 + 1) from calculus.
In the case that you're uncertain how to integrate t dt/(t^2 + 1) use the substitution u = t^2 + 1. However, you really should learn how to do these steps and properly apply elementary algebra - especially is you're working with DEs.
12K
