Generating Electricity from Mini Turbines: A Technical Support Guide
  • Thread starter Thread starter Rohan Mahadikar
    Support
Mini turbines can potentially generate electricity from water flow to an overhead tank, with the discussion focusing on estimating power output. The flow rate provided is approximately 1 liter every 18 seconds, which translates to a specific energy generation potential. To accurately calculate power output, the pressure or head of the water needs to be known, with an assumption of 10 meters of head yielding an estimated output of 5 Watts. The idea includes storing generated electricity in batteries for later use to save on home energy costs. Understanding the system's design and flow characteristics is crucial for accurate power generation estimates.
Rohan Mahadikar
I have an idea on placing mini turbines(just taking its principle into account) to water flow to over head tank and i have thought of generating electricity,so kindly help me with some technical help,what amount of power can be generated through this?
Welcome to PF!
How much water is being moved and how does it get there? Can you provide a diagram of the system?
russ_watters said:
Welcome to PF!
i don't have its diagram,but i can give you the flow rate of water=its approximately takes 18 seconds to fill a complete 1litre of water.can yo please provide me the power output that can be generated out of it,on an average atleast,i thought of storing it into battery and using it whenever it is necessary,so that i can save some unit of current in my home.
In order to find out the power you need the pressure. Since you don't seem to know, I'll just take a wild guess and assume it is 10m of head (pressure in units of height of water column). That would provide you a power of 5 Watts.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
