Generating Random Samples from Discrete and Continuous Random Variables
  • Thread starter Thread starter Tereno
    Statistics
8 replies · 3K views · last reply
Tereno
Hey guys I've got several questions about statistics.
Here's the first one.
1. Suppose X is a discrete random variable that takes on the three values x1, x2, x3 with probabilities p1, p2, p3 respectively. Describe how you could generate a random sample from X if all you had access to were a list of numbers generated at random from the interval [0, 1].
2. Suppose X is a continuous random variable with c.d.f. FX(x) = P(X  x). To make things easier, suppose further that X takes on values in an interval [a, b] (do allow for a to be −1 and b to be +1).
Let Y be the random variable defined by Y = FX(X). This looks strange, but is perfectly
valid since FX is just a function, and you are allowed to take functions of random variables.
Your problem: show that Y distributed U[0, 1].
Method: calculate the c.d.f. Y , FY (y) = P(Y  y), for all real y. Replace Y with FX(X),
and consider when you can take the inverse of FX.
Taking the inverse of FX is not always possible, in particular, for x < a and x > b. Consider
those cases separately.
You will find that the c.d.f. of Y is 0 for y < 0, y for 0  y  1, and 1 for y > 1, so indeed
An important application of this fact is that if u is a random selection from the interval [0, 1], F−1 X (u) is a random selection from X.
Tereno said:
2. Suppose X is a continuous random variable with c.d.f. FX(x) = P(X  x[/color]).
Regarding the part in blue[/color]:
My browser is showing that as "X square x", as in there is a square-shaped symbol between the X and the x. Is that what you meant? Does anyone else see it differently? Your post is riddled with those squares.
Concerning part 1. Find the pdf of X and call it f(t). Consider the
integral int(f(t), t,0,x)=y, where y is one of the numbers generated randomly from (0,1). Solve for x in the above integral. This will generate a quasi-random sequence of samplings of X.
P(X  x) = P (X <= x)
and P(Y  y) = P (Y <= y)
and the other two are strict inequalities <
Sorry for the confusion.
hmm..what do you mean by int(f(t), t,0,x)=y...??
o to x is the limits of integration?
My familiarity with part 1. comes from Monte Carlo Methods for Integration, in which a definite integral gets approximated by the expectation value of a random variable (who's pdf matches the argument of the integral). In order to sample the random variable, call it x, one creates the equation int(pdf(x),x,o,y)=z, where pdf(x) is the probability density function of the random variable x, y is the variable to be solved for, and z is a random sequence chosen from an arbitrary distribution. As you can see, my example deals with the continuous case, but I would imagine that the discrete case, such as yours, may be dealt with in the same manner.
Whoa..that's a little hard for me to understand. i don't think I've learn that yet.
And here's another question:
2. Suppose X is a discrete random variable that takes on values from {1, 2, 3, . . .} with probabilities
{p1, p2, p3, . . .}. If u is a number selected at random from [0, 1] explain why
min {sum from i=1 to n of p subscript i >= u}
can be considered as a random selection from X.
Don't you have to know according to which random distribution that list of numbers was generated? I think at the very least you have to assume that you know their distribution even if you don't assume what it is (e.g. uniform).
