Generic definition of derivative?
The discussion revolves around the definition of the derivative, particularly how it can be understood through the concept of error between a function and its tangent line at a point. The professor illustrated that the error diminishes when the slope of the tangent line matches the derivative of the function at that point. This leads to a useful approximation technique in calculus, allowing for simpler analysis of complex functions. The conversation also touches on the relationship between different definitions of the derivative and the tangent line, emphasizing their practical applications in both single-variable and multi-variable calculus. Understanding this concept is crucial for students as it lays the groundwork for more advanced mathematical analysis.
Hernaner28
Generic "definition" of derivative?
Hi. This is a theoric doubt I have since I went to class today. The professor "redifined" the derivative at point a. He draw a curve (the function) and the tangent at point a. Then he draw another two lines in the same point.
Well, then he said that the error is the difference between the lines and the function or I understood that (if it's not that way please clarify that to me).
So:
$$\eqalign{
& Error = f(x) - y \cr
& Error = f(x) - [m(x - a) + f(a)] \cr
& Error = f(x) - f(a) - m(x - a) \cr
& Error = \underbrace {(x - a)}_{\scriptstyle 0 \atop
\scriptstyle x \to a} \underbrace {\underbrace {\left( {\frac{{f(x) - f(a)}}{{x - a}} - m} \right)}_{\scriptstyle f'(a) - m \atop
\scriptstyle x \to a} }_{r(x)} \cr
& {\text{The error is minimum if m = f'(a)}} \cr
& {\text{so}} \cr
& \underbrace {f(x) = f(a) + f'(a)(x - a) + (x - a)r(x)}_{{\text{With }}r(x) \to 0{\text{ when }}x \to a} \cr} $$
Now... this is really interesting but I wonder what this is for... is this useful for sth in particular?
Thanks!
He's shown you two things.
First, he's shown you an interesting formula involving derivatives. This actually has quite a lot of practical use for coming up with good approximations, both in numeric and symbolic contexts. e.g. things like \sin x \approx x for small x, or to quickly estimate the value of \sqrt{101}.
It may not seem like a big deal now. One place where it really becomes useful when you are dealing with more complicated functions and expressions; knowing this formula and when to use it can allow you to replace the complicated function with something much simpler and easier to analyze.
Also, it turns out that this definition of the derivative generalizes well to other contexts, such as when you start doing multi-variable calculus.
The second thing he's shown you is a useful technique for computing / defining things. It's a surprisingly tricky issue to give a good definition of the term "tangent line" or to compute such a thing. But geometrically, we see that the tangent line can be approximated by a secant line. Turning that around, secant lines are approximated by the tangent line, and we can use this property to define the tangent line, as the one that gives the best approximation to the secant lines.
This technique is one of the main techniques of differential calculus: replace the complicated idea with a simple idea that approximates it. Show the approximations are well-behaved. Then, define the complicated idea to be the thing that the simple idea is approximating.
Oh yes, it seems really interesting. So, this could be really called another definition if we say?:
$$f'(a) = \mathop {\lim }\limits_{\scriptstyle x \to a \atop
\scriptstyle r(x) \to 0} \frac{{f(x) - f(a) - (x - a)r(x)}}{{x - a}}$$
I thought this was not a correct definition but now I see it's the same as:
$$f'(a) = \mathop {\lim }\limits_{x \to a} \frac{{f(x) - f(a)}}{{x - a}}$$
But I still haven't realize when it's convenient to use it. I guess I will learn it eventually.
Thank you!
Does this define the tangent or the derivative at a? I feel this is going to be really useful to know for my course so I want to understand it now before it becomes dense.
I got confused again. I don't know what this defines, if the derivative or the tangent and I don't see any differences between this and the formal definition.
Wikipedia shows this:
$$\lim_{h\to 0}\frac{f(a+h)-f(a) - f'(a)\cdot h}{h} = 0$$
But I cannot connect this expresion to the other one! Here there's no r(x)
Please help.. I need to get that clarified.
It works like this:
Let r_m(x) be the function
r_{m,a}(x) = \frac{ f(x) - f(a) - m (x-a) }{x-a}
Then we say f'(a) = m if and only if
\lim_{x \to a} r_{m,a}(x) = 0​
It can be rearranged a fair bit. The above is the same as saying
We say f'(a) = m if and only of
\lim_{x \to a} \frac{ f(x) - f(a) - m (x-a) }{x-a} = 0​
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
