Geometric Sequences help - (3 given terms, find the rest)
The discussion revolves around solving for the first term of a geometric sequence given specific terms and the common ratio. Participants explore the application of formulas related to geometric series, specifically the sum of the first n terms and the nth term, while seeking clarity on the steps involved in isolating the first term.
  • Homework-related
  • One participant presents the formulas for the nth term and the sum of the first n terms of a geometric series, expressing confusion about the process of isolating the first term.
  • Another participant provides a series of equations derived from the given values, attempting to substitute and simplify to find the first term.
  • Multiple participants express uncertainty about the steps taken to manipulate the equations, particularly regarding the handling of negative signs and the simplification of terms.
  • One participant suggests an alternative approach to find the first term without needing to solve for n first, emphasizing a more straightforward method.
  • There are repeated requests for clarification on specific algebraic manipulations, such as multiplying both sides of an equation and the implications of negative signs in the context of the geometric series.
Participants generally agree on the formulas to use but exhibit disagreement and confusion regarding the algebraic steps necessary to isolate the first term. There is no consensus on the best approach to take, with some preferring to solve for n first while others advocate for direct substitution.
Participants express varying levels of understanding regarding the algebra involved, indicating potential gaps in foundational knowledge that affect their ability to follow the discussion. The discussion also highlights the complexity of manipulating equations with multiple variables and the nuances of geometric sequences.
This discussion may be useful for students learning about geometric sequences, particularly those struggling with algebraic manipulation and the application of series formulas in mathematical contexts.
jaxx
I need to find the value of the first term for this geometric series.
Sn = 33
tn = 48
r = -2
I know that I have to take the formulas tn = t1 x r^(n-1), and Sn = [t1 x (r^n) - 1] / (r - 1), and isolate t1 for the first formula and then input that into the second, but I don't know the actual process of doing that.
If anyone can explain it step by step and with reasons maybe, that would be really helpful, I'm not good at math and get confused easily. Any help is appreciated
Mathematics news on Phys.org
We are given:
$$S_n=t_1\frac{1-(-2)^n}{1-(-2)}=t_1\frac{1-(-2)^n}{3}=33\,\therefore\,t_1=\frac{99}{1-(-2)^n}$$
$$t_n=t_1(-2)^{n-1}=48\,\therefore\,(-2)^n=-\frac{96}{t_1}$$
Now, substitute for $$(-2)^n$$ into the expression for $$t_1$$ to get:
$$t_1=\frac{99}{1+\frac{96}{t_1}}$$
Can you proceed?
sorry I'm not sure how you got to t1 = 99 / 1 - (-2)^n.
I get to 33 = t1[1 - (-2)^n] / 3, then wouldn't you multiply by 3 to get rid of the denominator, making it 99 = t1[1 - (-2)^n]?
either way I see you did multiply by 3, but I'm not sure what you did to flip the equation to get 1 - (-2)^n as the denominator, and Sn as the numerator.also when substituting in 99 / 1 - (-2)^n as t1 in the other formula, I'm not sure how to solve that. The equation would be 48 = [99 / 1 - (-2)^n] x (-2)^(n-1) right?
From there I'm not really sure how to go about solving it, I don't know if it's too much work for you to explain it all or not, but thanks for responding anyway.
Also at the end when you get (-2)^n = 96/t1, and then end up with t1 = (-2)^n, why does that 96 disappear? Or am I reading it wrong?
Okay, you are clear on how we get to:
$$99=t_1\left(1-(-2)^n \right)$$
Now, we may divide both sides by $$1-(-2)^n$$ to get:
$$\frac{99}{1-(-2)^n}=\frac{t_1\left(1-(-2)^n \right)}{1-(-2)^n}$$
On the right, divide out or cancel like factors:
$$\frac{99}{1-(-2)^n}=\frac{t_1\cancel{\left(1-(-2)^n \right)}}{\cancel{1-(-2)^n}}$$
And we are left with:
$$\frac{99}{1-(-2)^n}=t_1$$
jaxx said:
...also when substituting in 99 / 1 - (-2)^n as t1 in the other formula, I'm not sure how to solve that.
What I did was solve for $(-2)^n$ with the second equation, and then substituted that into the first so that $t_1$ is the only unknown, and this is the unknown we are trying to find.
jaxx said:
...The equation would be 48 = [99 / 1 - (-2)^n] x (-2)^(n-1) right?
This would allow you to find $n$, and then you could find $t_1$ from this, but I think my suggested method is more straightforward.
jaxx said:
...Also at the end when you get (-2)^n = 96/t1, and then end up with t1 = (-2)^n, why does that 96 disappear? Or am I reading it wrong?
I actually get:
$$(-2)^n=-\frac{96}{t_1}$$
because I multiplied both sides of $$t_1(-2)^{n-1}=48$$ by $\frac{-2}{t_1}$.
I believe you are reading it wrong, as I substituted for $$(-2)^n=-\frac{96}{t_1}$$ to get:
$$t_1=\frac{99}{1-\left(-\frac{96}{t_1} \right)}$$
You see, the $96$ is still there. Now we have an equation where the only unknown is $t_1$, which is what we seek. As the next step, I suggest multiplying both sides by:
$$1+\frac{96}{t_1}$$
What do you get when you do this?
Right, I get the first part now.
I get to t1 = -99 / -2^n - 1, and then substitute it into the tn formula like you did, which makes
48 = (-99 / -2^n - 1) [-2^(n-1)], and then multiply by -2 because it looks like that's what you did to get rid of it in the denominator.
So I get -96 = - 99 / (n - 1) x [-2^(n-1)], but from there I'm not sure what the next step is. I could multiply by n - 1 to get rid of the fraction, but that would just put the variable on both sides of the equation, which isn't what I want to do right?
If what I did was right, what's the next step?
It looks like you are still trying to solve for $n$ instead of $t_1$. If you follow my suggestion, you need not worry about finding $n$, as you get rid of it by substitution and have an equation in one variable, the one we are asked to find.
I guess I just don't understand at all why you would multiply both sides of t1(−2)n−1=48 by -2 / t1, and much less how to actually work through it from there.
I get why your way is easier, and it finds t1 instead of taking the extra step to find n and then produce t1, but if possible, would you mind showing me how to solve from here?
I understand it a lot more if I do it that way, even if it might be longer and takes the extra step to produce both variables instead of just the one I need.
Thanks for all your help so far as well.
No problem, I just wanted to point out that you get there more quickly the other way. So, let's go back to:
$$t_1\frac{1-(-2)^n}{3}=33$$
We may solving both for $t_1$ and then equate the results:
$$\frac{99}{1-(-2)^n}=\frac{48}{(-2)^{n-1}}$$
Multiplying the left side by $$-1=\frac{1}{-1}$$ and the right side by $$-1=\frac{2}{-2}$$ we get:
$$\frac{99}{(-2)^n-1}=\frac{96}{(-2)^{n}}$$
Cross-multiplying, we find:
$$99(-2)^n=96(-2)^n-96$$
Subtracting through by $$96(-2)^n$$, we find:
$$3(-2)^n=-96$$
Dividing through by $3$, we get:
$$(-2)^n=-32=(-2)^5$$
And so we must have:
$$n=5$$
Now you can find $$t_1$$ from this.
Using my suggestion above, we find:
$$t_1+96=99$$
$$t_1=3$$
This is the value you should find for $n=5$.
So why did you multiply by -1 = 1/-1? Can you not just multiply by 1/-1? Not sure I understand that bit, and multiplying by 2 / -2 gets rid of the -1 in (n - 1)? Also don't you have to multiply both sides of an equation by the same thing? Even though it is essentially the same but the negatives are different, I thought it had to be the exact same.
Also I'm not sure what you mean by 'subtracting through', when you simplify
99(−2)^n = 96 (−2)^n − 96
to get 3(−2)^n= −96.
I'm not sure how to simplify that, mainly I'm not sure how to get rid of the 2 "n" powers, or at least consolidate them into one.
Hello, jaxx!
Another approach . . .
[tex]\text{Given: }\;\begin{Bmatrix}S_n &=& 33 \\ t_n &=& 48 \\ r &=& \text{-}2 \end{Bmatrix}[/tex]
[tex]\text{Find the first term, }t_1[/tex]
[tex]\text{Formula: }\:t_n \:=\:t_1r^{n-1}[/tex]
[tex]\text{Then: }\:t_n \:=\:t_1(\text{-}2)^{n-1} \:=\:48[/tex]
[tex]\text{Hence: }\:t_1(\text{-}2)^n \:=\:\text{-}96\;\;\color{blue}{[1]}[/tex][tex]\text{Formula: }\:S_n \:=\:t_1\frac{1-r^n}{1-r}[/tex]
[tex]\text{Then: }\:S_n \:=\:t_1\frac{1-(\text{-}2)^n}{1-(\text{-}2)} \:=\:33[/tex]
[tex]\text{Hence: }\:t_1\left[1-(\text{-}2)^n \right]\:=\:99[/tex][tex]\text{We have: }\:t_1 - t_1(\text{-}2)^n \:=\:99[/tex]
[tex]\text{Substitute }\color{blue}{[1]}:\;t_1 - (\text{-}96) \:=\:99[/tex]
[tex]\text{Therefore: }\:t_1 \:=\:3[/tex]
There are usually many ways to solve an equation, it really boils down to personal preference, as long as the operations are all legal.
When I say "subtracting through," this means subtracting from both sides.
Once you get to:
$$3(-2)^n=-96$$
dividing both sides by 3 gives:
$$(-2)^n=-32$$
At this point, one can observe that $$-32=(-2)^5$$ and then you are left to equate the exponents to get:
$n=5$.
soroban said:
Hello, jaxx!
Hence: t1[1−(-2)n]=99We have: t1−t1(-2)n=99why did it become t1 - t1? where did that come from?also, how did you just get rid of "n" at the end? there was never a determined = t1 equation, and when you substituted [1] that had n in it as well, so how did it disappear?
Once you get to:
$$3(-2)^n=-96$$
$$(-2)^n=-32$$
$n=5$.
just out of curiosity, was I right when I got to this?
if so, am I right by multiplying by -2 to get rid of the (^n - 1), and ending up with -192 = (99 / n - 1) (-2n), dividing by -2, getting 96 = (99 / n - 1) x n? I don't know what to do from there but was I right up until that point?also what I meant was that I wasn't sure how
can become 3(−2)^n= −96. sorry for this taking so long, and thanks for the help
-96 = - 99 / (n - 1) x [-2^(n-1)]...
No, the denominator on the right is incorrect, it should be:
$$(-2)^{n}-1$$
Also, you should be aware that:
$$(-a)^n\ne -a^n$$
There is an order of operations issue at work. On the left, $-a$ is being raised to the $n$th power, while on the right $a$ is raised to the $n$th power, and then negated. If $n$ is odd, then they will be equal, but only because $(-1)^{2n+1}=-1$.
Okay, we have:
Subtracting $$96(-2)^n$$ from both sides, we get:
$$99(-2)^n-96(-2)^n=96(-2)^n-96(-2)^n-96$$
Now, if this is not clear that we have $$3(-2)^n$$ on the left and $-96$ on the right, then we may factor as follows:
$$(-2)^n(99-96)=(-2)^n(96-96)-96$$
Now, combine like terms:
$$(-2)^n(3)=(-2)^n(0)-96$$
and rewrite:
$$3(-2)^n=-96$$
Does this make more sense?
And please do not worry about how long it takes...we wish for our members posting questions to fully understand how to solve the problem. :D
$$(-2)^{n}-1$$
$$(-a)^n\ne -a^n$$
Okay, we have:
and rewrite:
$$3(-2)^n=-96$$
Alright thanks, my only question now is what it means to "combine like terms", and how you get 3 from 2^n(99 - 96)
The expressions:
$$99-96$$ and $$96-96$$
have like terms in that they contain numbers that may be subtracted to get:
$$99-96=3$$ and $$96-96=0$$
MarkFL said:
The expressions:
so for 99(-2)^n - 96 (-2)^n, since 3 factors into both 99 and 96, you can simply make it 3(-2n)?
No, we have 99 of something, and we are taking away 96 of them, leaving 3. For example:
$$99x-96x=3x$$
$$99u^3-96u^3=3u^3$$
$$99\sin(t)-96\sin(t)=3\sin(t)$$
$$99\int f(x)\,dx-96\int f(x)\,dx=3\int f(x)\,dx$$
$$99x-96x=3x$$
oh it's just subtraction, I see. Thanks very much for all your help then, I really appreciate it.
