Geometry problem with arcs in a triangle
16 replies · 2K views
albertoita
Thread moved from the technical forums to the schoolwork forums
In the figure, the point S is located inside the section FE.
Starting from S, as indicated in the figure, six circular arcs are drawn step by step around
arcs around A, C, B, A, C, B are drawn.
Show that the sixth arc leads back to S and that the six arcs together are then exactly as long as the two dotted arcs together.
no it,s an exercise I tried to do that my friend gave me 2 months ago and I still can't find an answer
PeroK said:
Is this homework?
theoretically it could be but only for my pleassure
PeroK said:
Is this homework?
could you find the answer with explanation
I don't know. My first thought is to use ##s = r\theta##, where ##s## is arc length subtended by angle ##\theta## on a circle of radius ##r##.
Have you tried that?
I've tried that.Didn't work.Could you try to like find a long explanation with math and words
It's nearly my bedtime!
Oh ok could you maybe try tomorrow find a long explanation and right explanation
Don't worry. There are more able mathematicians than me on here.
Problem seems trivial to me. Took me no time at all to figure it out and then quite a bit more time to draw this, so you can see it. Just to make sure it's clear, my "conclusion Z" follows from the geometry/arithmetic without ever drawing line 8
@albertoita I got a PM from you asking for more detail but the PM is closed to new posts so I can't answer you there. In any case, just follow the drawing of lines 1, 2, 3, 4, 5, 6, and 7 in that order. Clearly a = a1 = a2 = a3 and everything else is trivial arithmetic.
@albertoita I have now received THREE additional PM's from you asking for a complete and detailed explanation, all drawn out with great precision. Please STOP sending me these PM's.
I have spent as much time on this as I feel is necessary and I am not going to do anything more. I did you the favor of posting a complete solution in post #12. That's it.
I need to have a perfect solution .Everything must be shown perfectly
i don’t understand ur drawing
  • Sad
We do not provide solutions to schoolwork-type questions. That is your task, not ours. The thread will remain closed -- check your PMs.
