Getting currents in ammeter, with some resistances.
  • Thread starter Thread starter dhkdeoen
    Ammeter Currents
12 replies · 7K views
dhkdeoen
In the figure R1 = 1.29R, the ammeter resistance is zero, and the battery is ideal. What multiple of ε/R gives the current in the ammeter?
V=IR, 1/R=1/R_1+1/R_2..(when resistances are parallel)
etc
since ammeter doesn't have resistance, two top resistances and two bottom resistances are basically parallel. First, I set the currents coming out from the battery is i, and I was getting R_eq
R_top: R_1+R=(119/229)R
R_bottom: R/2
R_eq=R_top+R_bottom=(467/458)R
set the voltage as ε
ε=(467/458)*iR
ε=V_top+V_bottom=V_top+iR
(since two bottom resistances are same, so V_bottom=iR)
(467/458)*iR=V_top+iR
V_top=(467/458)*iR-iR=(9/458)*iR
and
i_topleft=V_top/1.29R=(9/458)iR*1/(1.29R)=(0.015233...)*i
i_A=current through ammeter
i_A+i_topleft=i
i_A=i-(0.015233..)i=(0.9847..)i
so I got 0.9847.. for the answer, which is wrong. where did I go wrong? I spent like 3 hours on this problem, and still can't get it.
The equivalent top resistance is not 119/229 R.
It is also wrong that Vbottom=iR.
It is better to do the derivation symbolically, and substitute the numerical data at the end.
ehild
I couldn't managed to pull out the answer, so I did what you said.
R_t=(R*R1)/(R+R1)
R_b=R/2
R_eq=(R*R1)/(R+R1)+R/2
ε=R_eq*i
ε=V_t+V_b=V_t+0.5iR
V_t=R_eq*i-0.5iR
i_topleft=V_t/(1.29R)
so
i_A+i_topleft=i
i_A=i-i_topleft
i_A=i-(V_t/(1.29R))=i-((R_eq*i-0.5iR)/(1.29R))=i-(((R*R1)/(R+R1)+R/2*i-0.5iR)/(1.29R))
R1=R*1.29
i_A=i-((1/2.29+1/2)i-0.5i)/1.29
since I won't need i in the answer
A=1-((1/2.29+1/2)-0.5)/1.29)=0.66148
http://www.wolframalpha.com/input/?i=1-((1/2.29+1/2)-0.5)/1.29
which is still wrong. I'll appreciate your correction on my attempt.
R_t=(R*R1)/(R+R1)
R_b=R/2
ε=R_eq*i
ε=V_t+V_b=V_t+0.5iR
V_t=R_eq*i-0.5iR
so
i_A+i_topleft=i
The equation in red is wrong if iAmeans the current through the ammeter.
ehild
I just realized I've mixed up my assumptions.
i_A+i_topleft=0.5i
is this right?
and, yes i_A is the current through the ammeter.
i_A+i_topleft=0.5i
is this right?
Yes, it is correct.
ehild
then it should be
i_A=0.5i-(((R*R1)/(R+R1)+R/2)*i-0.5iR)/(1.29R))
substitute R1=1.29R
i_A=0.5i-(1.06332iR-0.5iR)/(1.29R)
i_A=0.5i-(0.56332/1.29)i
i_A=0.5i-0.43668217i
i_A=0.06331877iI=V/R
i=ε/R
so this should be the answer, but still..
You made it a bit complicated. ((R*R1)/(R+R1)+R/2)*i=ε.
It is simpler with the topright current.
iA=i/2-itopright.
itopright=Vt/r
Vt=ε-ir/2.
iA=i-ε/r.
i=ε/Req, and Req=r(3r1+r)/(2(r+r1)). ..
ehild
iA=i/2-itopright.
itopright=Vt/r
Vt=ε-ir/2.
iA=i-ε/r.
ehild
it is! Maybe I was too hanging out with R1. Now I got the right answer.
Even though I got the right answer, I really should trying to get answer with R1, though. So much appreciated for your devotion!
gneill said:
Question: Have you studied Thevenin equivalents yet?
I don't think I've heard of that. My class just started with Kirchhoff's two rules.
dhkdeoen said:
then it should be
substitute R1=1.29R
i_A=0.06331877i
I=V/R
i=ε/R
You need the answer in term of ε/R, but i=ε/Req
By the way, the derivation is much simpler if you simplify whenever possible.
Vt= i(R1R)/(R1+R), Itopleft=Vt/R1=iR/(R1+R),
iA=i/2-iR/(R1+R)= i(R-R1)/(2(R+R1))...
ehild
Okay. I was just wondering what level of theory you'd covered. While problems like this one can be solved with basic Kirchcoff's laws, they become easier to tackle when you've covered some additional techniques. I thought perhaps it might have been an exercise intended to evoke such an approach. Never mind, carry on :smile:
