Getting most non-zero values near diagonal of matrix
  • Thread starter Thread starter Nask
    Matrix
To optimize a matrix for non-zero values near its diagonal, various algorithms can be employed, particularly those focused on matrix bandwidth or profile reduction. While the absolute optimal ordering for large matrices remains an unsolved problem, approximate methods can yield satisfactory results. The effectiveness of these methods often depends on the matrix's structure, necessitating experimentation with different algorithms. Standard methods typically apply to square matrices, but similar principles can be adapted for rectangular matrices by considering the diagonal from the top left to the bottom right. Understanding the concept of bandwidth reduction is crucial for further research and application in this area.
Nask
When I have a matrix like this:
0 0 1 0
0 1 0 0
1 0 0 1
0 0 1 1
0 0 0 1
I can get most non zero values in the centre changing only the order of rows
1 0 0 1
0 1 0 0
0 0 1 0
0 0 1 1
0 0 0 1
Probably when I am allowed to change the order of columns and rows at the same time I will even get a better result, getting rid of the 1 in the top-right corner.
Is there an algorithm that can be used to optimise a n by m matrix, having most of its non zero values near its diagonal?
Background:
The columns are the different client orders, the rows the different articles. I like to divide the clients that require a simular set of articles in different groups. The real amount of clients is about 500, articles about 2500, so I need an algorithm that also works for larger matrices (calculation has to be made each day upfront).
Thanks,
Nasko
The problem of how to find the absolutely "optimal" ordering for a large matrix, in a short enough time to be useful, is an unsolved problem.
There are many approximate methods that will produce "good" but not "perfect" orderings, ranging from quick single-pass methods to complex iterative algorithms. Search for matrix bandwith or profile reduction algorithms used in solving sparse linear equations.
Which method works best depends very much on the "shape" of the matrix. Often several different methods are tried, and the best result is used.
Note: the standard methods only work with square matrices. It is not quite clear what you mean by the "diagonal" of a rectangular matrix. But you should be able to use the basic ideas behind the methods to get what you want.
Thanks for both answers. Knowing the term bandwidth reduction helps a lot finding information on internet!
And for the diagonal of a non-square matix.. just the line from the top left to the bottem right... :-)
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
