Getting the wrong multipole for 1st acoustic peak
DoobleD
I'm trying to do a simple calculation, but there must be something wrong.
The wavelength ##\lambda_1## corresponding to first acoustic peak of the CMB is related to the sound horizon at last scattering, ##d_{hs}##, by :
## \lambda_1 = 2d_{hs} ## (see for instance slide 14 on Wayne Hu PDF slides).
Now, the multipole ##l## of the first acoustic peak can be related to its wavelength and to the distance to last scattering surface, ##D##, by :
##l_1 = \frac{2 \pi}{\lambda_1} D## (see slide 15)
From that I deduce the following equation :
##l_1 = \frac{\pi}{d_{hs}}D##
I find in the litterature that ##D \approx 14000 Mpc##, and ##d_{hs} \approx 150 Mpc##. I plug those values into the previous equation, and I find ##l_1 \approx 293##, which is quite far from the ##l_1 \approx 200## I should get for the first peak. What's wrong ?
I get the values for distance to last scattering surface and sound horizon here. I wonder however if 150 Mpc for the sound horizon is not in comoving coordinates, while I should use the physical distance instead (which I don't know) ?
EDIT : I just realized that at the very end of that WMAP values document, they basically give the exact same formula, ##l = \frac{\pi}{d_{hs}}D##. And with the values they gives, I get ##l = 299##. Why am I not getting 200 ?
I just found the exact same question asked by someone else on physics.stackexchange : https://physics.stackexchange.com/questions/222993/how-is-the-first-acoustic-peak-calculated-in-cmb
The guy also finds ##l \approx 300## instead of 200.
I'm back on this issue.
Same problem with again another source. We know that ##\theta_s = 0.0104## (slide 4), and ## l = \pi / \theta_s## (slide 18), so we get ##l = 302## instead of around 200. Exactly the same issue as in the https://redirect.viglink.com/?format=go&jsonp=vglnk_152494367988315&key=6afc78eea2339e9c047ab6748b0d37e7&libId=jgjovf9v010009we000DLcrw2gf0c&loc=https%3A%2F%2Fwww.physicsforums.com%2Fthreads%2Fgetting-the-wrong-multipole-for-1st-acoustic-peak.923207%2F&v=1&out=https%3A%2F%2Fphysics.stackexchange.com%2Fquestions%2F222993%2Fhow-is-the-first-acoustic-peak-calculated-in-cmb&ref=https%3A%2F%2Fwww.physicsforums.com%2Fsearch%2F81044411%2F&title=Getting%20the%20wrong%20multipole%20for%201st%20acoustic%20peak%20%7C%20Physics%20Forums&txt=https%3A%2F%2Fphysics.stackexchange.com%2Fquestions%2F222993%2Fhow-is-the-first-acoustic-peak-calculated-in-cmb post I linked earlier actually.
