Given f(x) = x^3 + 4x -5, show x-1 is a factor
  • Thread starter Thread starter DeanBH
The polynomial f(x) = x^3 + 4x - 5 has x - 1 as a factor, confirmed by evaluating f(1) = 0. The polynomial can be expressed in the form (x - 1)(x^2 + x + 5). The discriminant of the quadratic x^2 + x + 5 is calculated as b^2 - 4ac = -19, indicating that f(x) = 0 has one real root (x = 1) and two complex roots. This confirms that the polynomial has a single real solution and highlights the importance of understanding the discriminant in polynomial equations.
  • Understanding polynomial functions and their factors
  • Knowledge of the quadratic formula
  • Familiarity with the concept of discriminants in algebra
  • Ability to perform polynomial long division
  • Study the properties of polynomial functions and their roots
  • Learn how to apply the quadratic formula to find roots of quadratic equations
  • Explore the significance of the discriminant in determining the nature of roots
  • Practice polynomial long division to factor higher-degree polynomials
Students studying algebra, particularly those learning about polynomial functions, factors, and the quadratic formula. This discussion is beneficial for anyone seeking to understand the relationship between polynomial roots and their graphical representations.
DeanBH
The polynomial f(x) is given by f(x) = x^3 + 4x -5
show x-1 is factor :
f(1)=0
1+4-5=0 Thus it's a factor.
express in form (x-1)(x^2+px+q)
ends up being X^2 + X + 5.
next question is :
hence show the equation f(x) = 0 has one real root state it's value.
i know i have to use b^2 -4ac. If i do that it's -19 which is <0 so it's 1 value. But how do I find the value. And why does all this stuff work.
My teacher is one that just tells you how to do it. I have no idea why I'm doing it and it makes no sense so it's harder to remember. I would get 1or 2 marks out of 3 for this.
Firstly i don't know how to find out what the real number is. and i don't know why this works.
explain plez?! 8D
? Didn't you start off by showing that f(1)= 0??
And you are trying x so that f(x)= 0??
First a short lesson in discriminants, since you asked why you use them.
Remember the equation for the roots of any polynomial f \left(x \right) = a x^{2} + bx + c is
x = \frac{-b + \sqrt{b^{2} - 4 a c}}{2a} and x = \frac{-b - \sqrt{b^{2} - 4 a c}}{2a}
The term b^{2} - 4 a c is called the "discriminant". If the discriminant is negative, then in you would be taking the square root of a negative number, which you cannot do with the real numbers.
Now, how many roots must f \left(x \right) = x^{3} + 4 x - 5 have?
Do you know the value of any of the roots already?
DeanBH said:
Firstly i don't know how to find out what the real number is …
Hi DeanBH! :smile:
I think you're getting confused … the real number is 1, from the (x - 1) factor that you've already found.
When the question says "show the equation f(x) = 0 has one real root", it means exactly one real root (and two complex roots), instead of three real roots. That's all! :smile:
by working backwards, you can just show that x^3+4x-5 factors into (x^2+5)(x-1)
not sure if your teacher wants you to use the quadratic formula or not, but working backwards works just fine in some cases.
No, it doesn't.
(x2+ 5(x-1)= x3- x2+ 5x- 5, NOT x3+ 4x- 5. Did you mean (x2+ x+ 5)(x- 1)?
i don't think it's is a difficult question ? .
I believe that's already been pointed out several times!
HallsofIvy said:
No, it doesn't.
gah my bad, yes i ment (x2+ x+ 5)(x- 1)
  • · Replies 24 ·
  • · Replies 19 ·
