Given g(x)=xf(x), show g'(x)=f(x)+xf'(x).
  • Context: Undergrad
  • Thread starter Thread starter MooCow
The discussion focuses on demonstrating that the derivative of the function g(x) = x * f(x) is g'(x) = f(x) + x * f'(x). Participants clarify the use of the product rule and the definition of the derivative, emphasizing the importance of separating terms appropriately. The correct approach involves applying the limit definition of the derivative and manipulating the expression to isolate f'(x). The consensus is that using the product rule is essential for arriving at the correct derivative.
  • Understanding of the limit definition of the derivative
  • Familiarity with the product rule of differentiation
  • Basic knowledge of functions and their derivatives
  • Concept of continuity in functions
  • Study the product rule of differentiation in depth
  • Learn about the limit definition of the derivative
  • Explore the chain rule and its applications
  • Practice solving derivative problems involving products of functions
Students learning calculus, mathematics educators, and anyone seeking to understand differentiation techniques, particularly the product rule and its application in deriving functions.
MooCow
Problem:
Assume that f has a derivative everywhere. Set g(x)=xf(x). Using the definition of the derivative, show that g has a derivative and that g'(x)=f(x)+xf'(x).
What I know:
I know the definition of the derivative is [f(x+h)-f(x)]/h. I don't know how to plug it in and solve it though. I tried just plugging it straight in like
g'(x)=[x(f(x+h))-xf(x)]/h
I pulled the x out and the rest was [f(x+h)-f(x)]/h (the actual definition) and assumed it was xf'(x). I don't think that's right though.
Any help would be great and appreciated. Thanks in advance:]
What you want is this:
g'(x)=[(x+h)(f(x+h))-xf(x)]/h
What you are asking is called the "chain rule" You should be able to find all kinds of good stuff on google. Essentially, g(x) is defined everywhere, simply meaning that it is continuous (no breaks or sharp point)
To find the derivative of g(x) which is g'(x) you take the first component (i.e. x) and multiply it by the derivative of the second component (i.e. f'(x)). Then you take the second component (i.e. f(x)) and multiply it by the derivative of the first component (i.e. x' = 1). All this should lead you to your solution of g'(x)=f(x) + xf'(x)
Here is a break down step by step
g(x)=xf(x)
Step1
x*f'(x) ==> first component * derivative of the second component
Step 2
f(x) * 1 ==> second component * derivative of the first component
Step 3
Now add those two together
xf'(x)+f(x) to arrive at g'(x)=xf'(x)+f(x)
Yet another way to remember it
first times the derivative of the second + second times the derivative of the first.
Hope this helps!
I think it would be cheating to use the chain rule in the above problem.
Yea it would be. Technically I haven't learned that yet so it wouldn't be appropriate to use future processes.
However, even after obtaining the equation you gave me earlier, I still don't know what to do. I don't think I can pull out an (x+h) but that's the only thing I can think of doing...
When someone mentioned the chain rule above it was a hit.
You don't pull out an (x+h). In one term you pull out an x, the other therm is just f(x). The above problem is a special case of the product rule of differentiation. What you are looking to do is to separate the definition for the derivative of f(x) from the rest of the terms in your expression. You can separate these terms via product or sum.
In the numerator of
g'(x)=\lim_{h\to 0}\frac{(x+h)\,f(x+h)-xf(x)}{h}
add and subtract the term (x+h)\,f(x) and try to form the term
f'(x)=\lim_{h\to 0}\frac{f(x+h)-f(x)}{h}
Rainbow Child said:
In the numerator of
I don't know. That might work. There is a more obvious way to solve it though.
g'(x)=\lim_{h\to 0}\frac{x\,f(x+h)-xf(x)}{h}+\frac{h\,f(x+h)}{h}
The rest is left as an exercise.
It does work, because that's the way you prove the chain rule :smile:
I thought that was the case but it is certainly not the most obvious method.
