What is the difference between global and local maxima and minima?
The discussion clarifies the distinction between local and global maxima and minima in mathematical functions. A local maximum is defined as the highest value within a specific interval of a function, while a global maximum represents the absolute highest value across the entire domain. Examples provided include the function f(x)=x^3+x^2-17x+15, which lacks a global maximum, and g(x)=sin(x), which has global maxima at points defined by (\frac{\pi}{2}+2\pi n,1), where n is an integer. The analogy of mountain peaks effectively illustrates these concepts.
  • Understanding of basic calculus concepts, including functions and their properties.
  • Familiarity with the terminology of maxima and minima in mathematical analysis.
  • Ability to interpret graphical representations of functions.
  • Knowledge of trigonometric functions, particularly sine and their properties.
  • Study the concept of derivatives to identify local maxima and minima in functions.
  • Learn about the First and Second Derivative Tests for determining extrema.
  • Explore the application of maxima and minima in optimization problems.
  • Investigate the behavior of continuous functions and their limits to understand global extrema.
Students in mathematics, particularly those studying calculus, as well as educators and anyone interested in understanding the foundational concepts of maxima and minima in mathematical functions.
dev70
hi pf, this is my 1st math question. i am a undergraduate grade 12 student and my question is
what is the basic difference between local maxima minima & global maxima minima?
hi dev70! :smile:
the top of k2 is a local maximum
the top of mount everest is a global maximum :wink:
mathematically, what's the difference?
tell us what you think, and then we'll comment! :smile:
(if necessary, do some research on wikipedia etc :wink:)
If I may interject here. Take a look at this graph http://www.stat.purdue.edu/images/Research/Profiles/velocityReal2.jpg you'll see many humps (maxima). All the humps are local maxima in the sense that they are all peak values at their respective intervals. However, the one at around 0.58 is crowned the global maximum because not only is it the peak in its respective interval, but it is the highest of all the peaks in the entire function.
Take the everest example, you're asked to find the highest peaks in each country around the globe, and call each a local maximum. Then choose the highest peak of all, and call it a global maximum.
The same logic follows for minima.
I hope you found my answer helpful.]
A global maximum is the absolute greatest value that a function reaches on its domain. For example, the function f(x)=x^3+x^2-17 x+15 has no global maximum, but g(x)=\sin(x) has global maxima at (\frac{\pi}{2}+2\pi n,1),\,\,n\in\mathbb{Z}. A local maximum is the greatest value that a function reaches within a subset of its domain. For example, the local maximum of f(x) on the set \{x\colon -5<x<1\} occurs at (-\frac{1}{3}(1+2\sqrt{13}),\frac{1}{27}(560+208\sqrt{13})), but g(x) has no local maximum on the set \{x\colon 0\leq x<\frac{\pi}{2}\} (it would have one at the right endpoint, but that is not included in the set).
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 17 ·
