Global simultaneity surfaces - how to adjust proper time?
81 replies · 7K views
cianfa72
TL;DR
Adjust proper time for proper time synchronizable congruence of worldlines.
Hi,
searching on PF I found this old post Global simultaneity surfaces. I read the book "General Relativity for Mathematicians"- Sachs and Wu section 2.3 - Reference frames (see the page attached).
They define a congruence of worldlines as 'proper time synchronizable' iff there exist a function ##t## of spacetime such that ##d\omega= - dt##. The one-form ##\omega## is defined from ##g_{ab}Q^a## where ##Q## is the vector field the worldlines of the congruence are orbits of.
Said ##\gamma : I \rightarrow M## the generic worldline in the congruence we get ##du=\gamma^{*}dt## where ##\gamma^{*}## is the pullback of the map ##\gamma## -- from my understanding ##du## is such that ##du(\frac {\partial} {\partial u}) = 1##.
Then since ##du=\gamma^{*}dt## they claimed ##t \circ \gamma (u) = u + c##. I've some problem to grasp the reason behind it, though.
Can you help me ? thank you.
I'm not sure what your question is. Can you give more detail about what you are having problems with?
I have not a clear understanding why from ##du = \gamma^{*}dt## follows that ##t \circ \gamma (u) = u + c## where ##u## should be the proper time used as parameter along each worldline in the congruence.
p.s. said ##Q## the vector field tangents to worldlines ##\gamma## the following condition holds ##g_{ab}Q^aQ^b = g(Q,Q) = -1## (see the attached page in the post #1).
I don't see this claim being made anywhere in the page that you posted. I think you need to give more context from the book (I don't have a copy of Sachs & Wu so I can't check the reference directly).
At the end of the page they say that if ##h \circ \gamma## is not identically equal to 1, ##t \circ \gamma## no longer equals ##u## up to an additive constant.
AFAIU the coordinate on the real interval domain ##I## is ##u## so the curve ##\gamma: I \rightarrow M## is actually a function of ##u##.
So I think in our case in which ##t \circ \gamma=1## should be ##t \circ \gamma (u) = u + c##
In other words the proper time ##u## elapsed along each worldline between two given hypersurfaces ##t=a## and ##t=b## is exactly ##b-a##.
Ah, ok. So by implication if ##h \circ \gamma## is equal to ##1##, then ##t \circ \gamma## does equal ##u## up to an additive constant.
It's a mapping from real numbers (values of ##u##) to points in spacetime.
Not quite. ##t## is a mapping from points in spacetime to real numbers. So ##t \circ \gamma## is a mapping from real numbers to real numbers. This mapping maps the real number ##u## to the real number ##u + c## (where ##c## is some real constant). So if we wanted to include ##u## in the notation, it would be something like ##\left( t \circ \gamma \right) (u) = u + c##.
Maybe it is a simple/stupid question: why that implication is true ?
I'm just saying it's an implication of the way the book phrased the statement you quoted. You're the one who said I should look at that phrase when I said I didn't see the claim ##t \circ \gamma = u + c## being made anywhere in what you referenced.
Maybe I was unclear there. I think the point is that since each curve in the congruence has the property that its tangent vector field ##Q## fulfills ##g(Q,Q)=-1## then their spacetime lenghts (i.e. proper time along each of them) between ##u=a## and ##u=b## is exactly ##b-a##.
In other words the parameter ##u## is actually the proper time along each curve in the congruence.
Yes, this is correct. But that is always true for any timelike curve provided your curve parameter is properly normalized. So from this fact alone you can't deduce anything useful about particular congruences of timelike curves that have particular properties of interest, such as being synchronizable or proper time synchronizable.
Again, I'm not really clear about where you are having a problem with understanding.
Ok, section 2.3 defines 'proper time synchronizable' a congruence for which there exist a function ##t## such that ##\omega = - dt##.
Now integrating ##\omega## along a curve we get its lenght. On the other hand since ##\omega## is exact then its integral along a curve between two hypersurface ##t=a## and ##t=b## is exactly ##b-a##.
Is that correct ?
Yes.
Is that correct ?
Yes.
ok, now makes sense to me ##(t \circ \gamma) (u) = u + c##. Section 2.3 then claims each observer (i.e. each worldline in the proper time synchronizable congruence) can adjust/reset his clock so that its proper time is 0 when his worldline intersects a given ##t=a## hypersurface.
Just to double check my understanding.
We have a smooth curve ##\gamma: I \rightarrow M##. It defines a tangent vector field ##Q## on its points in ##M##. Since the manifold ##M## is endowed of a metric tensor ##g## we can naturally associate to ##Q## the one-form ##\omega## defined as ##\omega = g(Q, \_ )##.
In a given coordinate chart ##\{x^{\mu}\}## on ##M## we get ##\omega= g_{\mu \nu}q^{\mu}dx^{\nu}## where ##q^{\mu}## are the components of ##Q## in the coordinate basis associated to ##\{x^{\mu}\}##.
Given a one-form ##\omega ## defined on a n-dimensional smooth manifold (e.g. 4D spacetime) we can always integrate it along a one-dimensional curve (in our case the curve ##\gamma##). The condition ##\omega (Q)=-1## along the curve ##\gamma## implies that the integral of ##\omega## along it is actually its length according to the metric ##g##.
Nothing you say here appears to be relevant to the actual question at issue. See below.
You're doing it backwards from the way your reference does it. Your reference defines a "reference frame" ##Q## on spacetime (the term "reference frame" is not defined in the excerpt you posted from your reference, but I assume it means something like a frame field), and then derives a set of curves which are the integral curves of this reference frame. ##\gamma## is just the name given to one of those curves (which one is immaterial). Note that when referring to the tangent vectors to the curves, which are the timelike unit vectors of the reference frame at each point, your reference uses ##u##, not ##Q##.
As noted above, in the notation your reference is using, this would be ##\omega = g(u, \_)##, since ##u## is the timelike unit vector of the reference frame.
Yes, as long as you understand the pitfalls in the notation you have adopted (and again, in the notation your reference is using, it would be ##u^\mu##, not ##q^\mu##). But your reference is not reasoning this way; nothing it says has anything to do with coordinate charts, and nothing it says requires choosing a coordinate chart to prove.
Yes, you can, but that's not what your reference is doing.
This condition is not just true along the curve ##\gamma##. It is true at every point of spacetime, from the definition of ##\omega## and the fact that ##Q## (or more properly ##u##) is a unit timelike vector field. And, as I have remarked more than once, this condition tells you nothing at all useful since it's just restating the fact that ##Q## (or more properly ##u##) is a unit timelike vector field.
Again, this is just restating the fact that ##Q## (or more properly ##u##) is a unit timelike vector field, so it is telling you nothing at all useful.
An obvious reason for this is that your post doesn't even mention ##t##, the time function on spacetime, so obviously you can't be answering the question of why ##\left( t \circ \gamma \right) (u) = u + c##.
What do you get if you just integrate both sides of the equation ##du = \gamma^* dt##?
This actually isn’t right - cianfa had the right idea. Sachs and Wu use the letter ##u## as the worldline parameter, and denote the tangent vector to ##\gamma## as ##\gamma_* u = (\gamma_* [d/du])(u)##. Meanwhile ##Q## is the vector field which generates the integral curves ##\gamma##, and ##\omega## is its metric dual.
Sort of. They define the 1-form ##du = - \gamma^* \omega##, but a 1-form is not the exterior derivative of a worldline parameter, it's the exterior derivative of a function on spacetime. So ##u## must be a function on spacetime that gives the worldline parameter at a given point in spacetime belonging to the integral curve of ##Q## that passes through that point. You're right that I misspoke when I said ##u## itself was the tangent vector; see below.
Near the top of the excerpt the OP posted, we see the equation ##\left( \gamma^* \omega \right) \left( d / du \right) = \omega(\gamma_*) = g(Q, \gamma_*) = g(\gamma_*, \gamma_*) = -1##. Here it looks like they are using just ##\gamma_*## to denote the tangent vector.
It’s not a function on space time, it’s the inclusion function (which is on the interval ##\mathscr{E}##)
No, ##\gamma_*## is the tangent vector field (which here coincides with ##Q##), whilst ##\gamma_* u## is the tangent vector at the point on ##\gamma## at worldline parameter ##u##
I don't see how that can be true if ##du## is a 1-form, but perhaps ##du## means something else. As I said in an earlier post, I don't have this reference, and the notation they are using is not one I have a lot of experience with.
The differential of a function is a 1-form
Yes, it is the inclusion of ##\mathscr{E}## in ##\mathbb R##, so basically it assigns to ##\mathscr{E}## the coordinate ##u##. So ##du## is the differential of coordinate ##u##.
Yes, that’s right. The one-form ##du## is the pullback of ##\omega## via the pullback ##\gamma^*##
The exterior derivative (which is what the ##d## operator appears to mean in the reference the OP gave) of a function on spacetime is a 1-form on spacetime. But you're saying ##u## isn't a function on spacetime, which means you can't apply the exterior derivative operator to it. That's why I'm confused about what ##du## is supposed to mean in the reference the OP gave. If the ##d## in ##du## just means "take the differential", which would make ##du## a "1-form" on ##\mathscr{E}##, not spacetime, then it seems like their notation is confusing, since they also use the same ##d## to mean "take the exterior derivative".
ergospherical said:
Nobody says that ##d## is only defined on functions on spacetime…
The exterior derivative operator on spacetime is a different operator from the "take the differential" operator on the space of functions over a manifold such as ##\mathscr{E}##.
I've been lazy in typing up to now, but I'll stop. What I've been typing as ##d## so far is actually ##\mathbf{d}## in the reference, and ##\mathbf{d}## is a standard notation for the exterior derivative operator. Whereas an ordinary ##d##, not boldface, is a common notation for "take the differential". So I'm confused why ##du## isn't just written that way in the reference, instead of ##\mathbf{d} u##, as it's actually written in the reference. ##\mathbf{d} u## is naturally interpreted as "take the exterior derivative of the function ##u## on spacetime". Whereas ##du## (no boldface) is naturally interpreted as "take the differential of the function ##u## on ##\mathscr{E}##", which is what you are saying it actually means.
But the reference you gave actually writes this as ##\mathbf{d} u = - \gamma^* \mathbf{\omega}##, which, per my previous post, doesn't really make sense. If ##u## is a function on ##\mathscr{E}##, and ##\gamma^*## is the pullback from spacetime to ##\mathscr{E}## (which makes sense), then it would seem more natural to write ##du = - \gamma^* \mathbf{\omega}##, to make clear that ##du## is the differential of a function on ##\mathscr{E}##, not the exterior derivative of a function on spacetime.
ergospherical said:
You’re making a distinction where there is none
Nonsense. There is most certainly a distinction between spacetime and ##\mathscr{E}##, since they're different manifolds, and therefore there is also most certainly a distinction between functions on spacetime and functions on ##\mathscr{E}##, and operators over such functions. There are of course mappings between these things, but saying there is a mapping between two things is not at all the same as saying they're identical.
