Gold Atom Count in O-Ring: 10.4x10^21
7 replies · 5K views
shreddinglicks
A golf O-ring is used to form a gastight seal in a high-vacuum chamber. The ring is formed from a 100-mm length of 1.5-mm-diameter wire. Calculate the number of gold atoms in the O-ring.
Volume of cylinder = PI*h*r^2
I got the volume of the cylinder:
PI*100*.75^2 = 176.7
I used the formula m = D*V:
density gold = 19.28 g/cm^3
amu gold = 196.97 grams
19.28*176.7 = 3406.776
I then multiplied by avogadro's number over amu.
3406.776 *(6.02x10^23 / 196.97) = 1.04x10^25 atoms
The answer should be 10.4x10^21 atoms. I'm thinking I messed up some unit conversion. I am unsure of where.
What are the units on your volume? What are the units on your density?
The density is g/cm^3
the volume is mm^2
I see the issue, how do I convert this? Is there a way to convert so I can cancel out a unit?
the volume is mm^2
Volume should be cubic something. mm^2 is an area.
To convert a volume in mm^3 to cm^3 think about the following:
Conversion factor * X mm^3 = Y cm^3
The conversion factor needs to have units of cm^3 on the top and mm^3 on the bottom. What about [( 1 cm/ 10 mm)]^3 ? I.e. can you use the conversion between cm and mm to come up with a conversion factor between mm^3 and cm^3 ?
I see, so I have [176.7 mm^3] * [1cm/10mm]^3
basically
176.7 / 10^3 = .1767
Numbers are OK, but in the final formula you again ignored units. That's the simplest way of making mistakes, as you have already seen. Don't do that.
