Golf Displacement: 4.19m, 20° North of East
  • Thread starter Thread starter Caitlin.Lolz.
    Ball Golf Vectors
The discussion focuses on calculating the displacement needed for a golfer to hole the ball in one stroke instead of three. The golfer's first putt is 4.0 m due east, the second is 3.0 m at 20° north of east, and the third is 0.50 m due north. Participants emphasize the importance of breaking down each putt into x and y components to find the resultant displacement. It is clarified that due east can be treated as the positive x-axis, simplifying the calculations for the components. Ultimately, the correct approach leads to successfully solving the problem.
Caitlin.Lolz.
A golfer, putting on a green, requires three strokes to "hole the ball." During the first putt, the ball rolls 4.0 m due east. For the second putt, the ball travels 3.0 m at an angle 20° north of east. The third putt is 0.50 m due north. What displacement (magnitude and direction relative to due east) would have been needed to "hole the ball" on the very first putt?
Magnitude, in meters, and Direction, degrees North of East.
X = Vxt (I think)
I tried to to draw a diagram of a vector but if I followed the directions exactly then the picture isn't a triangle. So, I attempted to find the X and Y components, but it doesn't seem right.
X) 3cos(20) + .50cos(90) + 4cos(70) = 4.19
I don't know what to do from finding the x and y components, or if I'm even finding the components correctly.
X = Vxt (I think)
If the golfer 3-putted it won't be a triangle, unless he was putting from the bottom of the hole.
You are on the right track ... sort of.
You need to separate each of the three vectors into x and y-axis components and then sum x and sum y separately.
That will be the resulting x and y component of the vector of the answer.
The magnitude will be given by the square root of the sum of the squares. And the direction by the angle that makes with a reference direction.
Ok - thank you. But, to find the x and y components don't I need to know the angles that go with each distance? How do I find the angle for 4 m East? or .50 m North? Thats mainly what I got stuck on. =].
Due east is a direction. If you choose your axis well you can eliminate terms.
In this regard choosing East as the positive x-axis should be a good choice. Then you know the x component is 4 and the y component is 0.
Once you define East then you should know where North is correct?
Thank you, that makes sense! And I got the problem right!
Good job then. Keep up the good work.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
