Good ideas concerning shortening and lengthening electrical impulses
  • Thread starter Thread starter freddyfish
    Electrical Ideas
The discussion revolves around methods to modify electrical impulses from a steady pulse source without altering the source settings. Participants explore techniques to shorten one pulse by 5 ns while lengthening another pulse by the same duration, considering the implications of high impedance instruments and the need to avoid reflections in the circuit.
  • One participant suggests using coaxial cable as a delay line to achieve the desired pulse modifications, proposing to split the signal and recombine it using logic gates.
  • Another participant recommends adding circuitry to generate the required pulses, indicating that pulse compression techniques exist but are typically used for very short or high-energy pulses.
  • A later reply questions the feasibility of using the signal source as a trigger for a separate circuit to create the two desired pulses.
Participants express differing views on the best approach to modify the electrical impulses, with no consensus reached on a single method. The discussion remains open to various techniques and considerations.
Participants acknowledge the challenge of achieving precise timing adjustments and the potential limitations of the proposed methods, particularly concerning the quality of waveforms produced.
Individuals interested in electronics, pulse signal processing, and circuit design may find this discussion relevant.
freddyfish
Hey
Basically, what I am wondering is if anyone has any great ideas how to change the electrical impulses from an impulse source giving steady pulses if you can't change the settings of the source.
What I would like to do is make send these impulses through two separate branches (they share the same impulse source) and shorten one impulse by 5 ns while lengthening the impulse through the other branch by the same amount. Each one of these branches contain an instrument with high impedance, and also I would like to avoid reflections in the circuit. The impulses are square waves with amplitude of order a few volt and the period is, say, 15μs.
Thanks
You should really ask this in the electronics sub forum. Do you care about the pulse amplitude? If you don't and if your signal is large enough, you could split the signal and try to put a meter of coax cable (look at your cable specs to get 5ns) as a delay line, then combine the signals again using an or-gate and an and-gate. In theory these speeds should be possible. But there are probably more elegant ways to achieve this.
freddyfish said:
Hey
Thanks
(Thread moved to the EE forum)
Can you just use the signal source as a trigger for a separate circuit that generates the 2 pulses that you want?
Same reaction: add the circuitry, if it's a matter of 5ns.
Things like pulse compression exist, but are meant for very short pulses or for very high energy. As well, users don't expect nice waveforms from these circuits.
Thank you all for your answers. Everything is now solved, so the problem is eliminated.
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 18 ·
9K
  • · Replies 20 ·
