Good latex editor for Mathematics?
14 replies · 5K views · last reply
christian0710
Hi, Just wondering: What Latex editor would you recommend for a beginner for writing a lot of mathematical equations?
I use TeXworks, which is pretty bare bones, but if you pair it with a lot of google searches for new commands makes for pretty rapid equation entering.
I have used Scientific Workplace, but that lends itself to building equations symbolically which is more time consuming if you are doing a lot of math. The benefit of SW is that it also has a lot of built in capabilities to evaluate math and incorporate plots.
Do you want to type out the Latex or do you want something oriented toward a drag-and-drop symbols interface?
I prefer to type the Latex and for that approach, try Gummi.
Technicenter or Lyx... Technicenter is compiled, and is equivalent to TeXworks. LyX is WYSIWYG and I have not spent too much time working with it.
Just a minimal warning as I ended up not using Lyx...maybe things have improved.
Several years ago, when I was looking for a latex solution, I read about Lyx...I was not 100% happy with it...details about it that affect compatibility. Precisely because it attempts to be WYSIWYG, it seems the latex behind the scenes is not pretty to say the least; I seem to recall something along the lines of Lyx having to include stuff that is not standard (making the source incompatible with typical latex processing tools) and making it difficult to edit the source directly when wanting to achieve something specific.
Emacs, obviously. :wink:
Seriously, I use Kile. I really like it. It has a sidebar where you can look up symbols, and nice project management. It's not WYSIWYG, but frankly, I think that's a good thing.
While participants think about replies I wish to say about the short experience in LaTex on this forum.
When I have tried to find out how to use LaTeX in this forum, I visited the following topics:
https://www.physicsforums.com/threads/how-to-use-latex-on-a-forum.82081/#post-677269
and
https://www.physicsforums.com/threads/how-to-use-latex-on-this-site.825702/
there are many links to tutorials and there are no even a one frase about LaTeX tags! LaTeX tags are still not standartized and every one novice needs to know what they are, and there is no an answer)
Just trying to edit the message can be seen in the lower left corner of the built-in editor link "Latex" and trying to type LaTeX you can see the link "Latex guide". Clicking and reading you can find that the tags are:
itex and /itex in brackets!
So the last expression of previous post has to be rendered as:
[itex]F_{e }=\frac{q _{1}\cdot q _{2}}{{{4\cdot \pi \cdot \varepsilon _{0}\cdot \varepsilon \cdot r}}^{2}}[/itex]
Alternatively can be applied tags \$$ (double dollar). So:
\$$F_{e }=\frac{q _{1}\cdot q _{2}}{{{4\cdot \pi \cdot \varepsilon _{0}\cdot \varepsilon \cdot r}}^{2}}\$$
will be rendered:
$$F_{e }=\frac{q _{1}\cdot q _{2}}{{{4\cdot \pi \cdot \varepsilon _{0}\cdot \varepsilon \cdot r}}^{2}}$$
that is interesting that using itex and /itex tags we have a little font:
These threads aren't as good as they should be, because usually 20 people recommend 20 different editors. I think TeXnicCenter is good for small documents.
The LaTeX guide for Physics Forums starts with a detailed explanation of the tags.
https://www.physicsforums.com/help/latexhelp/
It can also be found by clicking info (at the top right), help/how-to, latex primer.
In the time of everything online there is sharelatex.com
Depending on your operating system installing extra packages can be a little annoying. Sharelatex has most if not all well-known packages.
They also have great tutorials if you ask me.
Finally you can work on the same document with multiple people (hence share)
See if you like it, I know I did. (Although I also use kile when I don't want any possibility of distractions)
Emacs with AUCTeX, BibTeX and RefTeX. You never have to think about equation labels again, as they are automatically generated and looked up.
