High School What is the Worldline of a Quantum Particle Before and After State Reduction?
  • Thread starter Thread starter cube137
    Gr Particle
The discussion centers on the concept of a quantum particle's worldline in the context of General Relativity (GR) before and after state reduction. It highlights the incompatibility of GR, a classical theory, with the behavior of quantum particles, which do not possess well-defined worldlines. The double-slit experiment is cited as evidence that quantum particles can traverse multiple paths simultaneously, contradicting the notion of a single worldline. Participants agree that the original question is poorly framed and lacks a definitive answer. Ultimately, the consensus is that quantum mechanics and GR operate under fundamentally different principles.
cube137
In GR. What's the worldline of a quantum particle before and after it undergoes state reduction (before and after Born rule applied)?
GR is a classical theory. I'm not sure there's a good answer to your question, and I'm rather doubtful that a quantum particle can be represented as having a worldline at all. Consider the double-slit experiment, for example. A worldline would go through only one slit, the quantum particle goes through both.
Pervect is correct, GR is a classical theory, not a quantum theory, and quantum particles do not have worldlines. That means the OP question is not well posed and cannot be answered.
Thread closed.
Likes cube137
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 27 ·
