Grad of a generalised scalar function
The discussion revolves around proving a relationship involving the gradient of a scalar function defined in terms of a generalized vector function \( r = xi + yj + zk \) and its magnitude \( r = \sqrt{x^2 + y^2 + z^2} \). The original poster attempts to derive the expression for the gradient \( \nabla f \) and later explores the Laplacian \( \nabla^2 f \) of the function.
  • Participants discuss the application of vector identities and the chain rule in deriving the gradient. Questions arise regarding the correctness of expressions and the interpretation of terms like \( \nabla \frac{df}{dr} \). Some participants express uncertainty about the mathematical steps taken and seek clarification on the role of the unit vector and the magnitude in the expressions.
The discussion is ongoing, with participants providing insights and corrections to each other's attempts. Some guidance has been offered regarding the application of the chain rule, but there is still exploration of different interpretations and expressions related to the Laplacian.
There are indications of confusion regarding the mathematical manipulations and the assumptions made about the relationships between the variables involved. Participants are also addressing corrections to initial statements made in the thread.
Phyrrus
r=xi+yj+zk and r =[itex]\sqrt{x^2 + y^2 + z^2}[/itex] Let f(r) be a C2 scalar function
Prove that [itex]\nabla[/itex]f = [itex]\frac{1}{2}[/itex][itex]\frac{df}{dr}[/itex]r
Vector identities?
[itex]\nabla[/itex]f = ([itex]\frac{df}{dx}[/itex] , [itex]\frac{df}{dy}[/itex] , [itex]\frac{df}{dz}[/itex])
= df/dr]?
= [itex]\frac{df}{dr}[/itex][itex]\hat{r}[/itex] (unit vector of r)
= [itex]\frac{df}{dr}[/itex]r[itex]\frac{1}{r}[/itex]?
I'm pretty sure what I've attempted isn't mathematically correct in the slightest, though in my head it seems to make some geometric sense. Am I even close though?
Formally f(r) is the derivative with respect to vector r: f(r)=(df/dr)=(df/dr)˙r/r. To prove the statement in the problem expand f(r) with x, y, z, and see if it is equal to (df/dr)˙r/r, using that r=√(r2)
ehild
Sorry, I made a mistake in the OP, it's supposed to be
[itex]\nabla[/itex]f = [itex]\frac{1}{r}[/itex][itex]\frac{df}{dr}[/itex]r
Thanks for your reply, but I'm not really sure where the r=√(r^2) come into it? How do you arrive at the 1/r out the front? The only thing I can think of is that it's supposed to reduced it to a magnitude of only df/dr?
Sorry, I also made a mistake, leaving out 1/r. df/dr is multiplied by the unit vector [itex]\hat{\vec r}[/itex], so [itex]\nabla f=\frac{df}{dr}\vec r /r.[/itex]
You get it by applying the chain rule: [tex]\frac{df(\sqrt{(\vec r)^2})}{d\vec r}=\frac{df}{dr} \frac{d \sqrt{(\vec r)^2}}{d \vec r}=\frac{df}{dr}\left(\frac{1}{2}\frac{1}{\sqrt{( \vec r)^2} }\right)2 \vec r[/tex].
ehild
Thanks mate, finally got it in the end. Just a little bit stuck on part b of the question though, have to prove that:
[itex]\nabla[/itex]^2f = [itex]\frac{2}{r}[/itex][itex]\frac{df}{dr}[/itex]+[itex]\frac{d^2f}{dr^2}[/itex]
I've been using the vector identities so that I get:
= [itex]\frac{1}{r}[/itex][itex]\frac{df}{dr}[/itex]([itex]\nabla[/itex][itex]\bullet[/itex]r) +(r[itex]\bullet[/itex][itex]\nabla[/itex])[itex]\frac{1}{r}[/itex][itex]\frac{df}{dr}[/itex]
from here I get down to [itex]\frac{3}{r}[/itex][itex]\frac{df}{dr}[/itex]+r[itex]\bullet[/itex]([itex]\frac{1}{r}[/itex][itex]\nabla[/itex][itex]\frac{df}{dr}[/itex]+[itex]\frac{df}{dr}[/itex][itex]\nabla[/itex][itex]\frac{1}{r}[/itex])
This is where I am confused, what is [itex]\nabla\frac{df}{dr}[/itex] is it just [itex]\frac{d^2f}{dr^2}[/itex]?
And I keep getting [itex]\frac{df}{dr}[/itex][itex]\nabla[/itex][itex]\frac{1}{r}[/itex]=[itex]\nabla[/itex]f, which doesn't seem right.
No, it is [itex]\frac{d^2f}{dr^2}\frac{\vec r}{r}[/itex]
ehild
Ahhhh yes, got it, it all works out now. Thanks a lot mate.
But just how did you get that? I presume it's quite similar to the first question, chain rule again?
Yes, it is the chain rule again.:smile:
ehild
  • · Replies 36 ·
