Gradient Problem Move From P(-1,1)
  • Thread starter Thread starter Geometrick
    Gradient
To maintain the same height at point P(-1,1) on the surface z = (y-x^2)^3, the direction of movement must be perpendicular to the gradient of the function. The gradient at this point is actually the zero vector, indicating that any direction will keep the height constant. The initial computation suggesting a direction of v = <-2, 1> is incorrect due to the gradient being zero. Therefore, any movement from P will not change the height. The conclusion is that there is no specific direction needed to maintain the same height at this point.
Geometrick
You are at P(-1,1) on the surface z = (y-x^2)^3. What direction should you move from P so that your height remains the same?
So I basically do not want my height z to change. In this case, I will take a vector perpendicular to grad f(p), a simple computation shows that grad f(p) will be in the direction of <1,2>, so I take my direction v to be v = <-2, 1>.
I'm just wondering if this is correct?
I think you have the basic idea down, but have made a mistake in the "simple" computation. At (-1, 1) the gradient of f is the zero vector. Both components of the gradient have factors of 3(y - x2)2. When x = -1, y = 1, this factor is 3(1 - (-1)2)2, or 0.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
  • · Replies 22 ·
