Graphical Representation of Cross Product
1 reply · 4K views
jmtome2
Show graphically how [tex]\vec{a}\times\vec{x}=\vec{d}[/tex] defines a line. [tex]\vec{a}[/tex] and [tex]\vec{d}[/tex] are constants. [tex]\vec{x}[/tex] is a point on the line.
[tex]\vec{a}\times\vec{x}=a\cdot x\cdot sin(\theta)\cdot \hat{n}[/tex]
Not sure if the included relevant equation is even relevant in this case. In any case, trying to graph this as a line seems impossible. Holding [tex]\vec{a}[/tex] constant and varying [tex]\vec{x}[/tex] along the line must result in different values of [tex]\vec{d}[/tex] which breaks the constraints on the original problem. It seems to me as if the above equation could only have one solution and, therefore, result in a point, not a line.
The only way I see this working is to imply the the above equation has multiple solutions (points along the line). Is this possible? And, if so, could anyone explain it in a simple manner?.
It's the line created by the vectors that have their component perpendicular to a equal to x*sin(theta) (it's not exact, the vectors must stay in a certain sense at right of a, if not they created two lines), the vector product is for definition the product of a times the component of the other vector perpendicular to a, times a certain normal vector oriented with the ax of the plane. You can draw it int this way, taken a and x, draw a parallel line to a that passes for x
