Graphing a*b^0.3=constant: Which Variable Goes on the Y-Axis?
  • Context: High School
  • Thread starter Thread starter mech-eng
    Graphing hand
The discussion focuses on graphing the equation a*b0.3 = constant, specifically determining which variable should be placed on the x-axis and y-axis. The user successfully plotted values of b on the horizontal axis, calculated corresponding a values for a constant of 100, and observed a hyperbolic curve with a negative slope. The conversation also touches on the utility of online graphing tools like WolframAlpha and Desmos, as well as the potential for using logarithmic axes for linearization in experimental contexts.
  • Understanding of hyperbolic functions and their properties
  • Familiarity with graphing tools such as WolframAlpha and Desmos
  • Basic knowledge of logarithmic transformations in data analysis
  • Experience with plotting equations in a Cartesian coordinate system
  • Explore the use of logarithmic axes for linearizing non-linear equations
  • Learn how to use WolframAlpha for solving and graphing equations
  • Investigate the features of Desmos for advanced graphing capabilities
  • Research CAD software options for graphing and physics simulations
Mathematicians, students studying algebra and graphing, engineers needing to visualize equations, and anyone interested in using online graphing tools for mathematical analysis.
mech-eng
I would like to sketch the graph of equation a*b^0.3=constant for a and b are positive real numbers. How do I start?
Which one should be as y-axis, and which one be x-axis. This only affects the shape of the graph. The confusing part for me is that should I use b itself or b^03 as an axis?
Thank you.
Mathematics news on Phys.org
I put b in the horizontal axis and give it values 10, 15, 20, 25, 30, 35, 40, 45 and calculated b^0.3 values. I choose constant=100 and then dividing 100/b^0.3 values I calculate a values. The graph is a curve with negative slope, nonlinear shape but it is like it behaves almost linear between b=20 and b=35 values.
Thank you.
fresh_42 said:
Here's the graph ##ab^{0.3}=a \cdot (b^{0.3})=100## for control:
http://www.wolframalpha.com/input/?i=a*(b^0.3)=100
It's a hyperbola. The constants ##100## and ##0.3## are only a matter of scaling.
What is the name/category of this kind of web service? An online calculator?
Thank you
Thank you
I don't know, how it is named and by whom. Wolframalpha is a well-known company that provides solutions for simple equations. More detailed solutions and graphics have to be paid by a membership, but for a quick and dirty look-up, they are a good source. Here's another page with similar properties: https://www.desmos.com/calculator
Are there CAD versions and multiphysics versions of such programs?
Thank you.
Thank you.
I don't know. Perhaps you could search for them on Google. "free CAD software" of "physics simulations" could be a start.
In experimental work where you might be needing to determine the actual values for the exponent and the constant from your graph it is often useful to use log axes .
Simple example :
The function y = k . xn then it can be rewritten as log y = log k + n . log x
Plotted on log axes the graph curve now becomes a straight line with n and k being given by the slope and intercept .
Is this a linearization process? This is very confusing for me because shape of the original and converted one is different so what is same?
Thank you.
  • · Replies 45 ·
  • · Replies 16 ·
