Gravitation and Orbiting Satellites
This discussion focuses on calculating the height of a second satellite orbiting Earth using Kepler's Third Law. The first satellite has a period of 1.4 hours and is located 200 km above Earth's surface, while the second satellite has a period of 6.0 hours. By applying the formula (Ta/Tb)^2 = (Ra/Rb)^3, where Ta and Tb are the orbital periods and Ra and Rb are the distances from the center of the Earth, participants determined that the height of the second satellite above Earth's surface can be derived from the known parameters and the radius of Earth, which is 6.37 x 10^6 meters.
  • Understanding of Kepler's Laws, specifically Kepler's Third Law
  • Familiarity with gravitational force equations (Fg = Gm1m2/r^2)
  • Basic algebra skills for manipulating equations
  • Knowledge of unit conversions, particularly between meters and kilometers
  • Study Kepler's Third Law in detail to understand its applications in orbital mechanics
  • Learn about gravitational force calculations and their implications in satellite motion
  • Practice unit conversion techniques to ensure consistency in scientific calculations
  • Explore examples of satellite orbital calculations to reinforce understanding of the concepts
Students in physics or astronomy courses, educators teaching orbital mechanics, and anyone interested in satellite dynamics and gravitational physics.
ThenewKid
1. Two satellites are orbiting around Earth. One satellite has a period of 1.4hours and
is 200km above Earths surface. The other satellite has a period of 6.0h. Use Kepler's laws
and the fact the radius of Earth is 6.37 x 10^6meters to determine the height of the second satellite above Earths surface.
2. Keplers Third Law: (Ta/Tb)^2 = (Ra/Rb)^3
Fg=Gm1m2/r2
G=6.67x10^-11 Nm^2/kg^2
Msv2/r = GMeMs/r^2
g=Fg/m
g=9.80N/kg
g=GMe/Re^2
3. Ok first I know that Fg is equal to Fc, but I don't know the equation to find out Fc.
So I just decided to attempt to find out the period but dividing 6hours by 1.4hours and using that number (4.29 rounded) multipled it with 200km and got 858km. I then used
858km as the height of the 2nd satellite above the Earths surface. I also calculated the velocity of satellite one, which is 7.79 x 10^3 m/s (or just 7.8m/s) Now, since I am doing a long distance course and not good at all at algrebra, and the lack of good example question within the textbook and coursebook to go on, I stumped. The answer I have cannot be worth 5 marks from the work I've shown, but I just can't find any way to prove how my answer is correct with so little to go on.
You will only need to use Kepler's Third Law.
ThenewKid said:
2. Keplers Third Law: (Ta/Tb)^2 = (Ra/Rb)^3[/b]
You were given the orbital periods for both satellites, the altitude of one of the satellites, and the radius of the Earth. That information plus Kepler's third law are all you need to solve the problem.
So Ta=1.4hours and Tb=6hours
What I got after doing the first part of the equation is 0.054
Now Ra and Rb are pretty much the radius of the Earth, and when I finished
that equation all I got on my calculator was 1E36.
...These numbers don't really seem like the height of the second satellite no matter how
I look at it and add/subtract/multiple/divide them together.
Are you using r in meters and T in seconds?
Good.
Not so good.
Solve for Ra (you don't use Kepler's laws here) and then solve for Rb (here you do use Kepler's law).
That's not necessary here. The left-hand and right-hand side of the expression (T_a/T_b)^2 = (R_a/R_b)^3 are unitless. If you so wished, you could even express length in furlongs and time in fortnights with this question, so long as all lengths are expressed in furlongs and all times are expressed in fortnights.
What is important in this question is that all similar items (i.e., all lengths) be expressed in the same units. Here we have the radius of the Earth in meters and height in kilometers. Those units must be made commenserate with one another.
  • · Replies 39 ·
