Gravitation force caused by uniform rod
1 reply · 6K views
joex444
What is the gravitational force caused by a thin uniform rod of length L on a point mass located perpendicular to the rod at it's center? Assume the point mass is a distance R perpendicular to the rod.
[tex]g = - \frac{GM}{r^2}\hat{r} = - G\rho \int \frac{dV}{r^2}\hat{r}[/tex]
[tex]g = -G\rho \int \frac{Rdx}{\sqrt{x^2+R^2}^3}[/tex]
[tex]x = Rtan(\phi)[/tex]
[tex]g = -\frac{G\rho}{R} * ( \frac{x}{\sqrt{x^2+R^2}} )[/tex]
Using limits of integration from -L/2 to +L/2 to yield:
[tex]g=-\frac{2G\rho}{R}*(L/\sqrt{L^2+4d^2})[/tex] after removing a factor of 4 from the (L/2)^2 from the square root.
Since the y components cancel, I took theta to be the angle nearest the point mass, and called rhat cos(theta) which I evaluated to R/sqrt(x^2+R^2) which could combine with the r^2 in the denominator from the gravity equation.
If this is wrong, I'll be glad to provide more steps to see where I went wrong. I ended up with a 1/(x^2+R^2)^(3/2) in the integral, so I did a trig substition to integrate it, and came up with the formula wikipedia has in its irrational integrals table, so I'm pretty sure that's alright, but wasn't sure if I set it up right.
Looks okay to me. This is how I did it (I get the same integrand form)
[tex]d\vec{f} = \frac{Gdm}{R^2+x^2}\left(-\cos\theta \hat{i} + \sin\theta \hat{j}\right)[/tex]
where
[tex]\cos\theta = \frac{R}{\sqrt{R^2+x^2}}[/tex]
[tex]\sin\theta = \frac{x}{\sqrt{R^2+x^2}}[/tex]
The integrand over [itex]\hat{i}[/itex] is an odd, so it integrates to zero ([itex]x[/itex] ranges from [itex]-L/2[/itex] to [itex]L/2[/itex]). You get
[tex]\vec{f} = -\hat{j}G\lambda R\int_{-L/2}^{L/2}\frac{1}{(x^2+R^2)^{3/2}}dx[/tex]
