Gravitational Field Variation of Disc Orbitating Earth
The discussion revolves around a hypothetical scenario where the moon is modeled as a disc orbiting the Earth, with specific dimensions related to its mass and distance from the Earth's center of mass. Participants emphasize the need for an algebraic expression to determine the gravitational field variation at both the poles and the Earth's center of mass. The conversation highlights the importance of adhering to forum guidelines, particularly regarding homework submissions and the necessity of providing an initial attempt at solving the problem.
  • Understanding of gravitational fields and their calculations
  • Familiarity with algebraic expressions and their applications in physics
  • Knowledge of orbital mechanics and celestial body interactions
  • Experience with forum etiquette and homework submission protocols
  • Research gravitational field calculations for non-spherical objects
  • Study the effects of mass distribution on gravitational forces
  • Explore orbital mechanics related to disc-shaped celestial bodies
  • Review forum guidelines for academic discussions and homework help
Students studying physics, particularly those interested in gravitational theory and orbital mechanics, as well as forum users seeking guidance on homework-related inquiries.
LeoPedranjo
Moved from another forum, so homework template missing
Hey guys, take a look at this question if you may
Suppose the moon, instead of a sphere, is a disc orbitating the Earth ( the moon's total mass is equal to the disc's total mass), the intern radius of the disc is equal to half the distnce between moon and Earth's center of mass and the external radius equals double of the distance between moon and Earth's CM. Find an algebric expression that determines: a) the variation in the gravitacional field due to the disc in the north pole or south pole. b) the variation in the gravitational field due to the disc in Earth's center of mass.
That is the whole question. Will there be any effect on the poles at all? Considering that the Earth will pull the disc to its center...
Ty
Is this a homework question or just a random exercise? If it's hw, it should be posted on the homework forum.
Its hw, sorry!
LeoPedranjo said:
Its hw, sorry!
OK please repost in the appropriate homework section and use the homework template :smile:Dave
You will have to give an attempt at a solution to get help with this problem.
  • · Replies 23 ·
