Gravitational force acting between objects
6 replies · 2K views · last reply
Abu
4 10kg objects are located at the corners of a rectangle sides 2 meters and 1 meter. Calculate the magnitude of gravitational force on 1 due to the other 3.
(Same sort of idea)
3 1kg objects are located at the corners of an equilateral triangle of side length 1 meter
F= Gm*M/r^2
So, let's say that I am finding the gravitational force on 1 for the rectangle (labeling the rectangle clockwise starting from the top right). My first idea was to find the gravitational force between 1 and 4 which would be directly to the left.
Then I wanted to find the gravitational force between 1 and 2 which would be directly below the rectangle. Then I wanted to find the gravitational force between 1 and 3, which would be directly diagonal from 1.
So here are my calculations for those, in order:
Force on 1 due to 4: 6.67*10^-11 10*10/2^2 = 1.67*10^-9
Force on 1 due to 2: 6.67*10^-11 10*10/1^2 = 6.67*10^-9
Force on 1 due to 3: 6.67*10^-11 10*10/√5^2 = 1.334*10^-9
But I don't know what to do from here because my answer is wrong. Am I supposed to be adding these 3 forces together, or is there a vertical and horizontal component I am missing or something?
I am assuming that if I understand how to do the rectangle one, I'll be able to do the triangle one. I may need help with that one too though
If my question isn't clear, I'll be happy to clarify it for you. Thank you.
Yes, but as vectors. Do you know how to add vectors?
Do you mean you want me to split the forces into x and y components? like 1 to 4 would be in the x direction and 1 to 2 would be in the y direction?
Yes, and what about 1 to 3?
Okay so I found the angle with tanΘ=1/2, then Θ = 26.5 degrees
I found the component of 1 to 3 in the X direction to be:
cos26.5= x/1.334*10^-9 and it equals 1.193*10^-9
For the component of 1 to 3 in the Y direction I did:
sin26.5 = y/1.334*10^-9 and it equals 5.95*10^-10
and then adding the x and y components together now would make
X
1.67*10^-9 + 1.193*10^-9 = 2.862*10^-9
Y
6.67*10^-9 + 5.95*10^-10 = 7.3*10^-9
And then imagining this as a triangle with X and Y components, I just use
F = √(2.862*10^-9)^2 +(7.3*10^-9)^2
F = 7.8*10^-9 Newtons
Is this correct? Sorry for the late responses.
If so I think I'm going to try the triangle one next.
I would keep one more digit of precision here. Other than that, this all looks right now.
Thank you for your help, I appreciate it.
