Gravitational Force: between 3 objects ?
To calculate the gravitational force on a 5kg object placed between two 75kg masses, the forces from each mass must be determined separately using the formula F=G(m1)(m2)/r^2. The calculated gravitational force from the closer mass (0.25m away) is approximately 4.00356e-7 N, while the force from the farther mass (0.75m away) is about 4.4484e-8 N. Since the forces act in opposite directions, the net gravitational force on the 5kg object is found by subtracting the smaller force from the larger one, resulting in approximately 3.5587e-7 N. Understanding the inverse relationship of gravitational force with distance is crucial for these calculations. This approach effectively resolves the problem.
littlejim
Two 75kg masses are separated by a distance of 1 meter. a 5kg object is placed .25 meters from one of the masses, .75 meters from the other along the line joining the masses. What is the gravitational force on the object?
F=G(m1)(m2)/r^2
So for this I have started by calculating the force between each 75kg mass and the 5kg mass separately. I get 4.00356e-7 for the .25m distance, and 4.4484e-8 for the .75m distance.
Im not quite sure where to go from here to answer the question; i remember that as distance increases between two objects, the force of gravity between them is an inverse relationship. So I think that means here that the force with the .75m distance is like 1/9 of the other...or something like that. I have confused myself at this point. I just don't know how to proceed with this. :/
Hi littlejim, welcome to PF.
Forces due to two masses on the object are in the opposite direction. So, to find the net force, find the difference between them.
So just
(4.00356e^-7)-(4.4484e^-8)= 3.5587e^-7
Well that explains it. Thanks
  • · Replies 28 ·
  • · Replies 52 ·
