Gravitational potential energy from ∞ to r
The discussion focuses on calculating the change in gravitational potential energy by determining the work done by gravitational force when moving a mass from infinity to a distance r from another mass. The student struggles with proving the negative value of gravitational potential energy and suspects an error in the dot product calculation. Clarifications reveal that the notation used was incorrect, as the magnitude of displacement (dr) is always positive, leading to confusion in the integral's limits. The correct understanding emphasizes that the work done by gravitational force is positive when moving inward, resulting in a negative potential energy value. The student gains clarity on the proper application of the work integral and the signs involved in the calculations.
Saix7
Hello, I'm a high school student studying for the AP Physics test tomorrow. I've been having trouble proving the negative value of gravitational potential energy through working out the work integral. I will greatly appreciate any help and clarification.
Find the change in gravitational potential energy ##\Delta U## by calculating the work done by the gravitational force to bring a particle of mass ##m_2## from infinity, to a position at a distance ##r## from another particle of mass ##m_1##
$$\begin{align}\Delta U&=-W\\ U_r-U_\infty&=-W_G \\ W_F &=\int\vec{F}\cdot d\vec{r}\\ W_G &=\int^r_\infty \vec{F_G}\cdot d\vec{r} \end{align}$$
$$\begin{align}\vec{F_G}\cdot d\vec{r} &=-\frac{Gm_1 m_2}{r^2}\hat r\cdot -d\vec r\\ &=\frac{Gm_1 m_2}{r^2} dr\\ W_G &=Gm_1 m_2 \int^r_\infty \frac{dr}{r^2} \\&=Gm_1 m_2 \Big ( \frac1 \infty - \frac1 r\Big )\\ &=-\frac {Gm_1 m_2}{r}\\ U_\infty&=0 \\ U_r&=\frac {GMm}{r}\end{align}$$
Of course the answer should be negative, since ##\vec F_G## does positive work in moving a particle inwards from an infinite distance. The calculation works out fine when I move a particle from an arbitrary distance ##r## to ##\infty##, but not the other way around. I suspect that I may be working out the dot product wrong in the work equation. The way I see it is that both ##d\vec r## and ##\vec F_G## are in the negative radial direction, so their dot product is positive. Is the infinitesimal ##d\vec r## intrinsically always positive even if the displacement is in the negative radial direction?
You suspicion is correct. In fact, many people get confused about this.
First of all, note that you abused notation: you can't equate ##\vec{F}_G \cdot d\vec{r} ## with ## \vec{A} \cdot -d\vec{r} ## because you can't have ## d\vec{r} = - d\vec{r} ##.
Then you ditched ## d\vec{r} ## and introduced ## dr ##, which apparently denotes the magnitude of ##d\vec{r}##, which is always positive by definition. But then the subsequent integral does not make sense, because it ranges from a greater bound to a lower one, thus implying ##dr## is negative.
That's how you got the wrong sign.
I understand now, thank you very much voko!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
