Gravitational potential energy of a sphere of non-uniform density
The problem involves calculating the total gravitational potential energy of a sphere with a non-uniform density distribution that varies as 1/r². The sphere has a total mass of 6.7 solar masses and a radius of 1.3 solar radii, with the final answer required in units of 1041 Joules.
  • Participants discuss deriving the gravitational potential energy by integrating the mass of thin shells and considering the varying density. There are questions about how to incorporate the density function into the derivation and how to rearrange equations to express potential energy in a specific form.
Several participants have provided guidance on the integration process and the relationship between density and mass. There is an ongoing exploration of how to express the density constant in terms of known values, and participants are clarifying the steps involved in the integration process.
Participants express confusion regarding the integration steps necessary for non-uniform density compared to uniform density scenarios. There is a recognition of the complexity introduced by the varying density function.
mell0r
Find the total gravitational potential energy stored in a sphere with a 1/r2 density distribution if the total mass is 6.7 solar mass and the radius is 1.3 solar radius. Express you answer in units of 1041 Joules.
To derive the equation, i attempted to follow the same procedure in deriving the gravitational potential energy of a constant sphere, but with also considering the altering value of density throughout.
I started off by figuring out an equation for the mass in a thin shell of mass dM and width dr at radius r:
dM=4πr2ρ0dr
Then integrated to obtain an equation of the total mass of material already assembled:
M(r)=(4/3)πr3ρ0
After this, i plugged these equations into dU(r)=-((GM(r)dM)/r) and integrated again for an equation for gravitational potential energy:
U=G(16/15)π2ρ02R5
The problem is that i can't for the life of me right now figure out how to re-arange this into an equation of the form ((GM2)/R), as i can't simply plug in ρ=((M)/(4/3)πr3) like i did for the sphere of constant density...
Any help would be greatly appreciated - this has been irritating me for a while now!
Thanks.
dM=4πr2ρ0dr
How does the above incorporate the fact that density varies as 1/r2 ?
Presumably you should let the density be given by some function of r like ##\rho(r) = \frac{\rho_0}{r^2}##
M(r)=(4/3)πr3ρ0
U=G(16/15)π2ρ02R5
Thanks.
mell0r said:
dM=4πr2ρ0dr
M(r)=(4/3)πr3ρ0
Potential energy is the work done in bringing a unit mass from infinity to the center of sphere.
U=integral[from infinty to zero](F.dr.cos(x)) here x=0=>cosx=1.
now f is not constant. it is different outside the sphere and also inside(non uniform density).
Break the integral for outside the sphere and inside. Like for outside do integral[infinity to R]((G{M,integrated mass of the sphere)/r^2).dr).
Ah, yes, sorry - i meant to include that.
Even so, my mind is completely blank now.. How can i relate that function to my derivation from my ρ0 variable? :confused:
If you integrate dM to find the expression for the mass (which is a given value), then you can solve that for your ##\rho_0## (probably best to leave it in symbolic form for now).
Then you can redo the integration for the mass to find the mass of the sphere as a function of r. That is, M(r). Then you can go back to summing the potential energies of the shells.
So overall i'd be performing 3 integration's? What would be the difference between integrating for the mass and the mass as a function? This math seems completely new to me, and i would have Google searched to figure it out, but I'm not even sure what to search..
Sorry for being annoying haha! Thanks for your time so far though :smile:
The first integration is to determine the value (or expression for) your density constant in terms of the known values (total mass, total radius).
The second integration uses this constant expression to replace your previously unknown constant ##\rho_0## when determining an expression for the mass of a sphere of arbitrary radius. That is, M(r).
The third integration uses the above M(r) and dM(r) to sum the shell-wise contributions to the potential energy.
so I integrated dM=4πr2ρ0dr over 0 and R, i get M=[itex]\frac{4}{3}[/itex]πR3ρ0 and thus worked out ρ0 from re-aranging that equation. Is that correct so far?
I'm finding this so confusing, yet I can do the same derivation for a uniform density perfectly fine..
You need to integrate, [itex]\displaystyle\ dM=4\pi r^2\rho(r) dr=4\pi r^2\frac{\rho_0}{r^2} \,dr\,\[/itex] because [itex]\displaystyle\ \rho(r)=\frac{\rho_0}{r^2}\ .[/itex] Integrate this from 0 to R and set it equal to M to evaluate ρ0.
Thank you! so the integral would be M=4πRρ0, and therefore ρ0=[itex]\frac{M}{4πR}[/itex]??
mell0r said:
Thank you! so the integral would [STRIKE]be[/STRIKE] give M=4πRρ0, and therefore ρ0=[itex]\frac{M}{4πR}[/itex]??
Right !
Wow, there you go. I Don't think I've ever been as happy to see an equation before as i just have haha! Thank you SammyS, gneill and smatik for the fantastic help and for coping with me :-p
  • · Replies 43 ·
