Gravity Effects on Rod Length - Reference Sources
  • Level: Graduate
  • Thread starter Thread starter SinghRP
    Effects
52 replies · 10K views
yoron said:
And yes, I've also wondered about the equivalence there, how one G on a planet will correspond to one G constantly uniformly accelerating, relative their 'time dilation' relative some arbitrarily set 'frame of reference' in uniform motion. That's one of the trickiest, and most interesting questions I know. It's about how far you can take this equivalence. When Einstein defined that acceleration as a constant inertia/gravity acting on the accelerating frame I definitely agree, but their 'proportionality' seems much harder to define in form of time dilations and Lorentz contractions.
Just to clarify my previous comments about linearly accelerated twin and relating that to gravitational time dilation via equivalence principle. From the point of view of an inertial observer, a clock on the end of a spring performing sinusoidal linear accelerations will on a time averaged basis age less than the inertial observer (who is stationary relative to the clocks center of motion) only on the basis of the time averaged speed of the clock. To add any acceleration term would yield an error. As many would no doubt point out, mathematically it gets down to computing and comparing the world lines of the 'twins', and that is a function of relative velocities over time, with acceleration coming in only incidentally as means of generating the changed velocities. Must go. :wink:
Naty1 said:
In GR gravitation potential dilates time; In special relativity velocity dilates length and time.
Do you have an indice explaining the transition from velocity (in special relativity) to potential (in general relativity) ?
indeed if velocities would affect space-time in general relativity, the metric would be time dependent which were not reasonable.
I think you're missing the point.
In general relativity, the metric coefficient for g_00 can be apprxoimated as (1-2U), where U is the Newtonian potential.
It's the metric coefficeint which causes time dilation and it's not velocity dependent.
In sepcial relativy, the metric coefficeints are always unity. So the time dilation in SR isn't coming from the metric coefficients.
The equivalence between acceleration and gravity is only "local". Over any significant distance or any significant length of time, the equivalence breaks down because gravity curves spacetime. See below.
In flat spacetime, yes. In curved spacetime, no. As pervect pointed out, the metric coefficient g_00 can also cause time dilation if it is different from 1. This time dilation can't be due to relative motion, since two objects at rest relative to each other at different heights will experience different rates of "time flow". But it can't be due to "acceleration" either, as you point out, because it's easy to construct examples of observers experiencing the same acceleration but with different rates of time flow.
The resolution of this apparent dilemma is that, in the presence of gravity, spacetime is curved; and in particular, around a static gravitating body, spacetime is curved in such a way that the worldlines of static observers at lower heights are shorter than the worldlines of static observers at higher heights. This difference in length appears, physically, as a difference in rate of time flow, because the worldlines in question are timelike.
(A more precise way of stating this is: if we pick as our simultaneity convention the simultaneity of observers very, very far away from the gravitating body, which is the simultaneity convention of the Schwarzschild time coordinate t, then all the static observers at various heights above the gravitating body will agree on which events are simultaneous, but they will disagree on how much time elapses between two given sets of simultaneous events; observers at lower heights will see less time elapse than observers at higher heights.)
Actually that is an interesting proposal.
Can I challenge you demonstrate it with numbers and formulas? I think this would be of great didactic value.
Indeed two stationary test observers at different r values in a Schwarzschild solution show different time flow as you call it but can you demonstrate that is not due to the difference in proper acceleration?
Similarly with various test observers radially free falling at different relative velocities, their proper time derivative is all different when they at an instant all fly by at the same location, but can you demonstrate that is not due to the Lorentz factor?
For instance:
A stationary test observer at a given r coordinate value undergoes constant acceleration to resist the escape velocity at that location.
The escape velocity at a given r is (rs is the Schwarzschild radius):
[tex]\Large v_{{{\it escape}}}=\sqrt {{\frac {{\it rs}}{r}}}[/tex]
While the time dilation is:
[tex]\Large d\tau_{{r}}=\sqrt {1-{\frac {{\it rs}}{r}}}[/tex]
However if we simply take the escape velocity and apply the Lorentz factor we get the same time dilation.
Thus how would you want to prove any gravitational time dilation through this method? :wink:
And the same situation arises for the various free falling test observers.
Observers at varying radii on disks rotating at varying angular velocities. By varying the radius and angular velocities appropriately you can pretty much achieve any combination of proper acceleration and linear velocity relative to the center of the disk that you want, subject of course to restrictions on velocities not reaching the speed of light.
Sure, because the different time flow is due to g_00, while the acceleration is due to the radial rate of change of g_00. By varying the mass M of the central body and the radius r, you can achieve pretty much any combination of rate of time flow and acceleration you like.
If observers are in relative motion, the relative motion always contributes to their comparative rates of time flow, but in general it won't be the only contribution. If all the observers are also at exactly the same radial coordinate r above the same central mass M, obviously their relative velocities are the only respect in which they differ, so in that particular case, that's the only thing that *can* contribute to a difference in rate of time flow. That's not the type of case we've been talking about, or at least I don't think it is; but I agree that it's always good to clarify exactly what can affect what.
Peter I mean by demonstrating using a test situation and formulas to prove it. It is so because it is so, is just a tautology.
I just added some formulas to my prior posting to show you what I am getting at.
So far in this thread we've been talking about static observers only, or at least I think we have. Saying that a static observer's time dilation arises from "resisting escape velocity" is fuzzy reasoning; I don't understand how it validates your derivation of the time dilation factor, since a static observer is not moving at escape velocity in the coordinates in question.
You are correct that freely falling observers are different; in fact, since they *are* moving inward at escape velocity, you could argue that your time dilation formula should apply to them, *not* to static observers. Unfortunately, you left out an important piece of information: a freely falling observer is changing his r coordinate as well as his t coordinate, so to calculate his rate of time flow you have to integrate dtau along his worldline using both the dt^2 and the dr^2 terms in the line element; you can't just look at g_00 like you can for static observers. This is easier to do in Painleve coordinates, particularly if you want to carry the computation inside the horizon. You've posted such calculations in these forums before, so I know you know how to do them; such a calculation is also given on the Wikipedia page on Painleve coordinates:
http://en.wikipedia.org/wiki/Gullstrand–Painlevé_coordinates
They would be moving wrt to a rain frame in GP coordinates. It is simply a matter of perspective and coordinates.
Again I wait for you to show a case with formulas to prove what you claim.
How about this:
Let's take three observers:
rs=1
O1 = Stationary at R1
O2 = Free falling at escape velocity at R1
O2 = Free falling at 0.5* escape velocity at R1
If we consider their resp tau differentials at that location can we prove their differences are gravitational instead of velocity based?
Can you show it with math?
I described how to set up the "test situations" you speak of, but sure, I'll post a few formulas as well to give more detail on how it goes.
(1) Observers at radius r on a disk rotating with angular velocity [itex]\omega[/itex], in flat spacetime, have a linear velocity v and proper acceleration a of:
[tex]v = \omega r[/tex]
[tex]a = \frac{\omega^{2} r}{1 - \omega^{2} r^{2}} = \frac{\omega v}{1 - \omega^{2} r^{2}} = \omega \frac{v}{1 - v^{2}}[/tex]
It should be obvious from the above that I can first pick whatever v I like (subject to the constraint 0 <= v < 1), and then adjust [itex]\omega[/itex] appropriately so as to make a assume any value > 0 that I want, by adjusting r in concert with [itex]\omega[/itex] so as to keep their product constant and equal to v. So I can choose v and a independently and achieve any combination of the two within the constraints, as I said.
(2) Observers "hovering" at a constant radial coordinate r above a gravitating body experience time dilation and proper acceleration of:
[tex]\frac{d\tau}{dt} = \gamma = \sqrt{1 - \frac{2 M}{r}} = \sqrt{1 - 2 U}[/tex]
[tex]a = \frac{M}{r^{2} \sqrt{1 - \frac{2 M}{r}}} = \frac{U}{r \gamma} = \frac{1}{r} \frac{U}{\sqrt{1 - 2 U}}[/tex]
So again, it should be obvious that I can pick any value for [itex]\gamma[/itex] that I like (subject to the constraint that [itex]\gamma > 1[/itex]), which fixes the ratio M/r = U, and then use the second formula to adjust r appropriately, adjusting M in concert with r to keep U constant, to make a assume any value > 0 I want. So again I can choose [itex]\gamma[/itex] and a independently and achieve any combination of the two within the constraints, as I said.
No, static observers are not moving relative to GP coordinates. The GP radial coordinate r is defined the same as it is for Schwarzschild coordinates, so the orbits of static observers, which are lines of constant r, theta, phi in Schwarzschild coordinates, are also lines of constant r, theta, phi in Painleve coordinates. The only thing that changes between Schwarzschild and Painleve coordinates is the surfaces of simultaneity; in Schwarzschild they are orthogonal to the static observers' worldlines, but in Painleve they are orthogonal to the worldlines of observers freely falling inward "from infinity".
Passionflower said:
How about this:
rs=1
Obviously not, since the case you posed has all three observers at the *same* radial coordinate, and I already said that in that special case, the relative velocity *is* the only contribution. I was merely saying that if we have observers at *different* radial coordinates, who also happen to be in relative motion, there will be a contribution from their relative velocity *and* a contribution from the difference in heights. The GPS satellites are an example; the adjustment to their clock frequencies to make GPS time run at the same rate as UTC includes an adjustment for height *and* an adjustment for relative velocity.
It depends on the chosen coordinates if the difference in heights constitutes a velocity or not.
Rain frame Peter, I am talking about a rain frame in GP coordinates.
I am fully aware of your point I merely wanted to demonstrate that from another perspective it is velocity based instead of gravitational based.
Huh? I'm not sure what you're getting at here. If you mean that the term "relative velocity" does not have a unique well-defined meaning in curved spacetime for observers that are spatially separated, yes, you're correct; one would have to settle on a specific meaning for the term. The one I had in mind was velocity relative to the Earth-Centered Inertial frame, since that's the relative velocity definition that was used, for example, to analyze the results of the Hafele-Keating experiment, but I should have made that explicit.
I think there is no need to settle anything. I think that considering multiple viewspoints of things tend to enrich understanding.
That was all I wanted to show. :)
You mean rain frame as defined on the Wiki page?
As that line element is written, it mixes two different radial coordinates, so I'm not sure what it's supposed to mean physically. I don't believe such a frame is valid globally. I see the Wiki page references Taylor-Wheeler, I'll have to break open my copy and re-read their discussion of it.
Edit: Oops, read "Taylor-Wheeler" and immediately thought "Spacetime Physics" without reading the actual book title on the Wiki page. I don't have Exploring Black Holes but it's on my list to get.
You might also want to search for Lemaître observers.
Sulu: Captain! The stars. they are gone! We can't navigate!
Spock: Captain, I am locating an unidentified large object rapidly approaching us, with increasing speed. (Lemaitre)
Captain: Scottie, full speed reverse.
Scottie: Aye captain! Captain, we keep the engines at full speed and we are now just staying ahead of this 'thing'. Soon we will deplete our dilithium crystals. (Static)
Spock: Captain, I have a theory, it might work.
Scottie: We are just about to burn all of them out captain!
Spock: We should stop the engines and give some small lateral impulse power.
Captain: Sulu do it now!
Sulu: Captain it works, but now this thing is following us at a constant distance. (Hagihara)
Captain: Following us? Is it intelligent Spock?
It all depends on the point of view!
For instance:
This is what I meant, using the equivalence principle to compute the speed of the local inertial frame.
This velocity of escape is calculated with a classical kinetic energy : U = 1/2mv^2
However shouldn't we use a relativistic expression : U = mc2*(1/Sqrt(1-v2/c2) - 1) ?
Then we find the velocity throuh equating with the potential energy : GMm/r2
The energy of a test observer in a Schwarzschild solution is constant as long as it travels on a geodesic.
You can use the following equality:
[tex]\Large E=\sqrt {1-{\frac {{\it r_s}}{r}}}{\sqrt {1-{v}^{2}}} ^{-1}[/tex]
So if you know the energy at one location it is very easy to calculate either the velocity or position at another location or velocity.
For instance it is easy to see that the energy of an observer free falling at escape velocity is exactly 1, just plugin vescape in the equation above.
From the energy we can get the apogee of a test radial observer, because when the velocity is zero we get:
[tex]\Large E=\sqrt {1-{\frac {r_{{s}}}{r_{{{\it ap}}}}}}[/tex]
Or alternatively we can get the apogee from the velocity at a given r value:
[tex]\Large {\frac {r_{{s}}}{r_{{{\it ap}}}}}=- \left( {\frac {r_{{s}<br /> }}{r}}-{v}^{2} \right) \left( {v}^{2}-1 \right) ^{-1}[/tex]
If 1-2U is an approximation, Do we know the exact form of g_00 ?
The exact form of g_00 is (1-2M/r) in Schwarzschild coordinates, and geometric units. Of course it's worth remembering that often other coordinates are used. For instance isotropic coordinates, which make the speed of light the same in all directions for small M/r and are used in the PPN approximations would make
g_00 = [(1-M/2r) / (1+M/2r) ]^2
This still approaches 1-2M/r if you series expand it in 1/r, however ...
(1-2M/r + 2M^2/r^2 - (3/2) M^3 / r^3 + ...)
(1-2U) is symbolically identical to the first expression in Schwarzschild coordinates, but the r in that expression stands for the Newtonian radius, not the Schwarzschild r coordinate, so the resemblance is formal and not an identity.
