Understanding the Discrepancy: Why Does the Moon Have Less Gravity Than Earth?
  • Context: Undergrad
  • Thread starter Thread starter Pierre Ordinaire
    Earth Gravity Moon
The Moon has 1/6 the gravity of Earth despite being 1/81 the mass due to its lower density. The gravitational force is determined by the formula g = GM/R², where G is the gravitational constant, M is mass, and R is the radius from the center of the mass. If the Moon had the same density as Earth, its surface gravity would be approximately 1/4 that of Earth's. The discussion highlights the importance of both mass and density in understanding gravitational differences between celestial bodies.
  • Understanding of gravitational force and the formula g = GM/R²
  • Basic knowledge of mass and density concepts
  • Familiarity with celestial mechanics
  • Awareness of comparative planetary science
  • Research the effects of density on gravitational force in celestial bodies
  • Explore the gravitational differences between Earth and other planets, such as Saturn
  • Study the implications of gravitational force on space exploration and lunar missions
  • Investigate the relationship between mass, radius, and gravity in astrophysics
Astronomers, physics students, educators, and anyone interested in understanding the gravitational properties of celestial bodies.
Pierre Ordinaire
TL;DR
Gravity on Earth vs the Moon.
Apologies in advance if this has been touched before. If the Earth has 81 times the mass of the Moon, why the Moon has 1/6 of the gravity of the Earth?
Astronomy news on Phys.org
Do you find that strange? What do you think it ought to be instead of 1/6?
Acceleration due to gravity increases with mass and decreases with distance squared from the center (outside spherically symmetric bodies, anyway). The moon is less massive but much smaller. If you built a tower on the moon so high that you were as far from the center as the radius of the Earth, gravity there would be 81 times weaker than the surface gravity if the Earth. But "on" the moon usually means on the surface, much closer to the center than on a huge tower.
Thank you.
Pierre Ordinaire said:
Summary:: Gravity on Earth vs the Moon.
See:
https://phys.org/news/2016-01-strong-gravity-planets.html
For example: Saturn has 95 times more mass than Earth, but about the same surface gravity:
  • Wow
A.T. said:
See:
Of course that is due to the fact that Saturn has a density that is 1/8 that of the Earth's.
In the same vein, The Moon has a lower density than the Earth. If it had the same density as the Earth and the same mass, its surface gravity would be closer to 1/4 the Earth's rather than 1/6.
I assume that means "the same mass as the actual Moon". Not "the same mass as the Earth" - then it would be identical. Obvious if you think about it, but at a first reading it looked wrong.
Yes, I meant the moon's current mass.
g=GM/R^2. Work that out.
  • · Replies 33 ·
  • · Replies 18 ·
