Gravity vs Inertia: Newton's Law of Gravitation Explained
  • Context: Undergrad
  • Thread starter Thread starter johnny_bohnny
    Gravity Inertia
The discussion revolves around Newton's law of gravitation, exploring the relationship between gravity and inertia, the existence of inertial reference frames in the presence of gravitational forces, and the implications of these concepts in various scenarios. Participants raise questions about the effects of gravity over large distances and the interactions between small masses.
  • Some participants question whether an inertial frame can exist under the influence of gravitational forces and how inertia might affect acceleration due to gravity.
  • There is a discussion about the negligible gravitational forces between small objects, such as a desk and a ball, and why these forces do not result in noticeable motion.
  • Some participants assert that inertial frames are idealizations and exist only approximately, while others argue that for practical purposes, the world behaves as if these frames are valid.
  • Participants explore the concept of acceleration between distant objects, such as Earth and Alpha Centauri, and whether the distance affects gravitational interaction.
  • There are inquiries into how gravitational forces from various masses can be considered negligible and how this relates to the concept of inertial frames.
  • Some participants provide mathematical formulations related to gravitational acceleration and the forces acting on two bodies.
  • Questions arise about the cancellation of gravitational forces and how this affects the perception of motion and acceleration in a Newtonian context.
Participants express differing views on the nature of inertial frames in the presence of gravity, with some asserting that they exist approximately while others challenge this notion. The discussion remains unresolved regarding the implications of gravitational forces on small masses and the overall understanding of acceleration in various contexts.
Limitations include the dependence on idealizations of inertial frames, the assumptions about the negligible effects of distant gravitational forces, and the unresolved nature of how these forces interact in practical scenarios.
johnny_bohnny
As it's stated in Newton's law of gravitation, every object with mass attracts all other object with a force which causes acceleration. So basically there are infinite number of forces in our universe which affect our planet as well. My question is, can an inertifal frame (which has the net force of zero) exist in these condition, and does inertia itself play a role in determining acceleration due to gravity. If we have two objects many many miles aparat, and one has a much greater mass, will the heavier object still accelerate relative to the lighter one.
Think about this: when and where was the last time you felt the effect of the gravity from Alpha Centauri?
Zz.
Zz.
Never, of course. But does that mean that there is no acceleration between Earth and Alpha Centauri because of the great distance or something else?
Or to add a sub-question, why don't small objects like my desk and my ball for instance pull each other causing motion between them, since they also have gravity?
Inertial frames are an idealization, and exist in nature only approximately.
Gravity is a VERY weak force! So between things which don't have much mass (anything smaller than say, asteroid sized), or things which are far away (e.g. Alpha Centauri) you probably wouldn't be able to feel any attraction at all. For things on your desk, the force between them is so tiny it's negligible.
Why not try to plug in some numbers and see for yourself? Newton's law of gravitation says:
$$F=\frac{G m_1 m_2}{d^2}$$
Where F is the force, G=6.67*10^-11 N*m^2/kg^2, m1 and m2 are the masses (express them in kilograms to get the right units), and d is the distance between the masses (express it in meters for the right units).
Try something like m1=1kg, m2=1kg, and d=1m.
So inertial movement in practice is very debatable because of many gravitational forces from different masses?
No, it's the other way around. In practice it is not in the least bit debatable because the gravitational forces are so negligible that for most practical purposes the world acts like the idealization.
So do there exist inertial frames in our universe, despite gravity? (if we look at the classical picture, without GR)
For instance is the Sun an example of an IRF?
We've been giving you the same answer for the past several posts now...
There are APPROXIMATELY inertial reference frames all around. These frames are to a very good approximation, inertial. From a Newtonian viewpoint, the reference frame you are in right now, at your computer, is approximately inertial. The gravitational force from the Earth is being balanced by the normal force of the ground on which you stand. Your acceleration is very nearly 0.
In addition, the factors making your current frame of reference not exactly inertial, is not the gravity from all the other stars/objects in the universe, because all of these forces are being canceled out by the gravity of Earth and the normal force of the ground. The reason your frame of reference is not exactly inertial is due to the rotation of the Earth, and the rotation of the Earth about the Sun, and the rotation of the Sun about the center of the galaxy. The largest factor, the rotation of the Earth, still has negligible effects in comparison to much of your every day observations.
Considering the classic equation :
a = ( G * ( m1 + m2 ) ) / d ²
The a refers to the total acceleration of both bodies.
The individual accelerations of m1 and m2 :
acceleration, m1 = ( m2 / ( m1 + m2 ) ) * a
acceleration, m2 = ( m1 / ( m1 + m2 ) ) * a
Can anybody please explain the bolded part, how is this cancelling of forces achieved basically? Shouldn't any object still pull the Earth with objects that are on its surfaces because of its gravitational force, so what does cancelling out really mean?
And I've red that an apple falling to Earth still attracts Earth so that Earth moves towards the apple, why doesn't this effect get canceled out?
Can anyone please explain the previously mentioned effect and its applications on Earth and other objects with mass, because I still haven't found a relevant answer.
In a Newtonian frame of reference, if you are sitting at your desk and the Earth were not rotating, you would NOT be considered to be accelerating. The force of gravity of the Earth pulls you down, the force of gravity of everything else pulls you very very little bit in other directions. The normal force exactly cancels all the left over forces (which is 99.99% going to be from the Earth).
  • · Replies 51 ·
  • · Replies 49 ·
  • · Replies 22 ·
  • · Replies 41 ·
9K
  • · Replies 138 ·
10K
