GRE Math Problem #57: Subring of R[x] From Real Numbers
  • Context: Graduate
  • Thread starter Thread starter jammidactyl
The discussion centers on GRE Math Problem #57, which examines subsets of the ring of polynomials R[x] over the field of real numbers R. The subsets in question are: I) polynomials with a zero coefficient for x, II) polynomials of even degree, and III) polynomials with rational coefficients. The correct answers are I and III, as subset II does not contain a multiplicative identity, which is essential for it to qualify as a subring under certain definitions. The distinction between rings and rings with unity is highlighted as a critical concept for understanding this problem.
  • Understanding of polynomial rings, specifically R[x]
  • Familiarity with the definitions of subrings and rings with unity
  • Knowledge of the properties of polynomial degrees
  • Basic concepts of field theory, particularly related to real numbers
  • Study the properties of polynomial rings in more depth
  • Research the definitions and examples of rings and rings with unity
  • Explore counterexamples in ring theory to solidify understanding
  • Review GRE Math preparation materials focusing on abstract algebra
Students preparing for the GRE, particularly those focusing on advanced mathematics, educators teaching abstract algebra, and anyone interested in the properties of polynomial rings and subrings.
jammidactyl
I'm reviewing the practice booklet for the GRE and came across a question I can't solve. Problem #57 for reference.
http://www.ets.org/Media/Tests/GRE/pdf/Math.pdf
Let R be the field of real numbers and R[x] the ring of polynomials in x with coefficients in R. Which of the following subsets of R[x] is a subring of R[x]?
I. All polynomials whose coefficient of x is zero.
II. All polynomials whose degree is an even integer, together with the zero polynomial.
III. All polynomials whose coefficients are rational numbers.
I figured the answer was "all of the above", but the answer in the back says just I and III.
If you add or subtract two polynomials of even degree, you get another polynomial of even degree or the zero polynomial. If you multiply two polynomials of even degree, the answer also is a polynomial of even degree. Since it's a subset and satisfies these conditions, isn't II a subring?
I think I'm making a really simple mistake with some obvious counterexample.
Does II have a multiplicative identity?
It only needs an additive identity to be a subring, which it has.
Apparently it depends on which definition of the term "ring" you're used to! This is good information to know for the test... never realized there was such a difference.
  • · Replies 0 ·
  • · Replies 69 ·
9K
