Green's function & Klein Gordon
The discussion focuses on the application of Green's function in the context of the Klein-Gordon equation, specifically the integral representation given by \int \frac{d^4p}{(2\pi)^4}\frac{i}{p^2-m^2}e^{ip\cdot(x-x')}. It is established that this representation leads to an infinite result when evaluated at x=x', indicating that the particle described by the Green's function is localized at that point. Furthermore, the relationship between the Green's function and the two-point function correction is explored, revealing that the Green's function serves as a position space propagator for the Klein-Gordon equation.
  • Understanding of Green's functions in quantum field theory
  • Familiarity with the Klein-Gordon equation
  • Knowledge of four-vector notation and integrals in quantum mechanics
  • Basic concepts of perturbation theory and two-point functions
  • Study the derivation and properties of Green's functions in quantum field theory
  • Learn about the implications of the Klein-Gordon equation in particle physics
  • Explore the concept of position space propagators in quantum mechanics
  • Investigate the role of symmetry factors in perturbation theory calculations
Physicists, particularly those specializing in quantum field theory, graduate students studying particle physics, and researchers interested in the mathematical foundations of quantum mechanics.
Sekonda
Hello,
I was wondering what the use in the Green's function for the Klein-Gordon equation was, I have listed it below:
[tex]\int \frac{d^4p}{(2\pi)^4}\frac{i}{p^2-m^2}e^{ip\cdot(x-x')}[/tex]
We find this gives an infinite result when the Klein gordon equation is applied to it and if x=x', what does this mean, i.e.
[tex](\frac{\partial^2 }{\partial t^2}-\nabla^2+m^2)\int \frac{d^4p}{(2\pi)^4}\frac{i}{p^2-m^2}e^{ip\cdot(x-x')}=i\delta^{4})(x-x')[/tex]
Does this mean the particle described by the green's function in the first equation can only be found in one place when x=x'?
Also if we set x=x', the Green's function above turns to
[tex]\int \frac{d^4p}{(2\pi)^4}\frac{i}{p^2-m^2}[/tex]
Which is alike to the 2 point function first order correction of form
[tex]-\frac{i\lambda}{2}\int \frac{d^4p}{(2\pi)^4}\frac{i}{p^2-m^2}[/tex]
What is the relationship here? What use are the Green's function to the above equation? p is the four vector :
[tex]p=(E,\mathbf{p})[/tex]
Thanks,
SK
I'm now aware that the first equation in my previous post is also a position space propagator for the Klein-Gordon equation; would anyone be able to explain to me why for this diagram
The correction to the 2 point function for this first order can be given as an integral over the 3 position space propagators associated with (x',x'), (x,x') and (x',y)?
Along with the -iλ/2 from the vertex (/symmetry factor = 1/2)
Thanks
  • · Replies 24 ·
  • · Replies 41 ·
