Griffiths E&M Problem 3.15: Solving a 3D Bounded Region
  • Thread starter Thread starter ehrenfest
    Griffiths
ehrenfest
This question refers to Griffiths E and M book.
Obviously this is a 3D problem and we should use Example 3.5 as a model. However, since the region of interest is bounded in all 3 directions doesn't that mean that all of C_1, C_2, and C_3 need to be negative? But then C_1+C_2+C_3=0 is impossible! The constants C_i that I am referring to are on page 135.
Laplacian
\nabla^2 V = 0
After separation of variables:
\frac{1}{F}\frac{d^2 F}{dx^2} + \frac{1}{G}\frac{d^2 G}{dy^2} + \frac{1}{H}\frac{d^2 H}{dz^2} = 0
Argument: How can a function of x and y and z added together be zero always?
Mindscrape said:
Laplacian
\nabla^2 V = 0
That is my point! If
\frac{1}{F}\frac{d^2 F}{dx^2}=C_1
\frac{1}{G}\frac{d^2 G}{dy^2}=C_2
\frac{1}{H}\frac{d^2 H}{dz^2} =C_3
Then C_1 +C_2+C_3 must be 0 which means that not all the C_i can be negative, which is absurd because we need trig functions not exponentials since the region is bounded in all three directions??
Absolutely, positive constants will give the trivial solution.
Why not say -C1-C2-C3=0? Does it really matter whether the constants we make are negative or positive, aren't they allowing the functions to *sum* to zero in either case?
Why not exponentials? It seems like the potential will start at Vo at z = a, then decay (exponentially) down the z axis.
Try to apply the boundary conditions to exponentials. It may be easier if you write them in terms of sinh and cosh in this case.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
