Griffiths Electrodynamics gradient of charge distribution
The discussion centers on the application of the chain rule in Griffiths' Electrodynamics, specifically regarding the gradient of charge distribution as presented in Equation 10.21 on page 424. The participants clarify that the charge density p is a function of both spatial coordinates and retarded time tr, which necessitates the inclusion of time derivatives in the gradient. The gradient of charge density, expressed as \nabla \rho, incorporates derivatives with respect to retarded time, confirming the application of the chain rule in this context. The conversation concludes with a consensus that understanding this relationship is crucial for grasping the nonstatic case of charge distribution.
  • Understanding of Griffiths' Electrodynamics, particularly the concepts of charge density and retarded time.
  • Familiarity with calculus, specifically the chain rule and partial derivatives.
  • Knowledge of vector calculus, including gradients in three-dimensional space.
  • Basic concepts of electromagnetism and continuity equations.
  • Study the chain rule in multivariable calculus to reinforce understanding of its application in physics.
  • Explore the concept of retarded time and its implications in electrodynamics.
  • Review the continuity equation in the context of charge conservation in electromagnetic theory.
  • Examine additional examples of gradients in electromagnetism to solidify comprehension of spatial and temporal derivatives.
This discussion is beneficial for physics students, particularly those studying electromagnetism, as well as educators and researchers looking to deepen their understanding of charge distribution dynamics and the mathematical principles involved.
Sparky_
I do not understand the following from Griffiths’ Electrodynamics – page 424 Equation 10.21.
<br /> \nabla p = \dot{p} \nabla {tr} = …<br />
I’m not sure how much of this applies (I think my question is on the math) but p is the charge distribution, tr is the retarded time.
Is this an application of the chain rule?
With the gradient being a derivative with respect to spatial location (x,y,z), why is the time derivative showing up in the gradient? I initially want to say if something is dependent upon t but not on x, then its derivative with respect to x is zero.
The result looks like the chain rule applied – I don’t see why the time dependent portion shows up.
Can you help clear this up for me?
Thanks
Sparky_
continuity equation?
I do not see it yet.
I see later on the same page
<br /> \nabla \dot{p} = \ddot{p} \nabla {tr} = …<br />
Can you explain further?
Somehow the gradient is giving an additional time derivative.
Thanks
Sparky_
\rho has arguments like this:
\rho (\vec{r}&#039;, t_r(\vec{r}, \vec{r}&#039;, t))
The gradient is being applied w.r.t to the coordinates of \vec{r} ( not \vec{r}&#039; which gets integrated away). The coordinates that we would be taking the derivative with respect to in order to obtain the gradient are only found in the parameters of t_r. So this result is from the chain rule. Here is one component of the gradient, for example.
(\nabla \rho)_x = \frac{\partial \rho (\vec{r}&#039;, t_r(x, y, z, \vec{r}&#039;, t))}{\partial x} = \dot{\rho}\frac{\partial t_r}{\partial x}
Oh I see, did he specify that the dot derivative is with respective to retarded time?
It won't matter. ##\partial _{t_{r}} = \frac{\partial t_{r}}{\partial t}\partial _{t} = \frac{\partial }{\partial t}(t - \frac{\mathfrak{r}}{c})\partial_{t} = \partial_{t}##.
Anyways, as noted above ##\rho = \rho(r',t_{r}) ## and ##r'## is no longer a variable after integration but ##t_{r} = t_{r}(t,x,y,z,r')## so ##\nabla \rho = \partial _{t_{r}}\rho \nabla t_{r} = \partial_{t}\rho \nabla t_{r}##. Not sure what that has to do with the conservation of 4-current (continuity equation) ##\partial_{a}j^{a} = 0##.
Thank you!
I went back in this section of the text and reread. I see that p (charge density) is specified p(r’, tr). That is actually the point of this topic (the nonstatic case).
You confirmed that this is an application of the chain rule and p is a function of position and tr.
Thank you for the help!
Sparky_
  • · Replies 21 ·
