Ground state and 1st excited state energy of 3 Fermions
The discussion revolves around calculating the ground state and first excited state energies of three non-interacting fermions in a harmonic potential. The participant has derived the total energy expression using the Pauli exclusion principle but is uncertain about the correct quantum numbers for the states. It is clarified that the lowest energy state corresponds to n=0, and combinations of quantum numbers must be found that adhere to the exclusion principle for both ground and excited states. The importance of specifying the spin of the fermions is emphasized, as it affects the uniqueness of the solution. Overall, the participant seeks guidance on correctly applying these principles to solve the problem.
catpotato
So in my problem, there's a given of 3 non interacting fermions in a harmonic well potential. I already got the wavefunction but i have problems in obtaining the ground state energy and its 1st excited state energy for 3 fermions (assuming they are non interacting and identical)
En = E1 + E2 + E3
En = (n + 1/2) ħω
Since they are fermions, i tried applying pauli's exclusion principle so my En would be equal to: (n1 + 1/2) ħω + (n2 + 1/2) ħω + (n3 + 1/2) ħω
where n1 = 1, n2 = 2, n3 = 3 for the ground state.
I am not sure if this is right for fermions so I'm kinda stuck and still skeptic on how to solve for the 1st excited state. Any help would be much appreciated.
I'm no expert in this type of problem, but with opposite spins, shouldn't it be possible to have two particles in the lowest energy state?
i think so too, if there were two particles in the lowest energy then n1 and n2 will both be equal to 1? and n3 will be equal to 2?
I think the lowest state has ## n=0 ##. I think I have it right, but I am hardly an expert in this area. ## \\ ## Additional comment: For the wave function, I think it is necessary to use a Slater determinant type waveform, but I would like to hear from someone with considerable Q.M. expertise. ## \\ ##@bhobba Might you have an input here?
catpotato said:
En = E1 + E2 + E3
En = (n + 1/2) ħω
You have to be careful with the notation. Does the index n label the particle or the state of the h.o.?
Yes, that is correct.
You have to find the combinations of n that give you the lowest energy and then the next lowest energy without violating the Pauli exclusion principle. There might be more than one possible solution for the first excited state.
By the way, you haven't specified the spin of the fermions. It is very important here.
Likes Charles Link
DrClaude said:
You have to be careful with the notation. Does the index n label the particle or the state of the h.o.?Yes, that is correct.You have to find the combinations of n that give you the lowest energy and then the next lowest energy without violating the Pauli exclusion principle. There might be more than one possible solution for the first excited state.
oh i forgot, the En there is supposed to be the total energy of the particles and the spin wasn't specified in our homework.
I'm still not sure what the index n represents. If spin was not specified, then the solution is not unique.
