Why is D4 not primitive on the vertices of a square?
  • Thread starter Thread starter fishturtle1
    Blocks Group
The discussion addresses the primitivity of the groups S4 and D8 acting on the vertices of a square. It establishes that S4 is primitive on the set A = {1, 2, 3, 4} by demonstrating that any subset of size 2 or 3 does not remain invariant under the group actions. In contrast, it argues that D8 is not primitive, as it can find nontrivial blocks among subsets of the vertices. A key error identified is the assumption that certain permutations belong to D8, which is incorrect since not all transpositions in S4 are part of D8. The conclusion is that D8 has nontrivial blocks, confirming its non-primitive nature on the vertices of a square.
fishturtle1
Let ##G## be a transitive permutation group on the finite set ##A##. A block is a nonempty subset of ##B## of ##A## such that for all ##\rho \in G## either ##\rho(B) = B## or ##\rho(B) \cap B = \emptyset##. (here ##\rho(B) = \lbrace \rho(b) : b \in B \rbrace##).
c) A (transitive) group ##G## acts on a set ##A## is set to be primitive if the only blocks in ##A## are the trivial ones: the sets of size ##1## and ##A## itself. Show that ##S_4## is primitive on ##A = \lbrace 1, 2, 3, 4, \rbrace##. Show that ##D_8## is not primitive as a permutation group of on the four vertices of a square.
Proof: Let ##B = \lbrace a \rbrace \subseteq A## and ##\rho \in S_4##. We have two cases, ##\rho(a) = a## in which case ##\rho(B) = B##, or ##\rho(a) \neq a## in which case ##\rho(B) \cap B = \emptyset##. Its clear that ##\rho(A) = A##. So these sets are indeed blocks. Now let ##C## be any subset of ##A## such that ##2 \le \vert C \vert \le 3##. Then there is ##x, y \in C, z \not\in C## and ##\gamma \in S_4## such that ##\gamma(x) = z## and ##\gamma(y) = y##. This implies ##\gamma(C) \neq C## and ##\gamma(C) \cap C \neq \emptyset##. So ##C## is not a block. We can conclude ##S_4## is primitive on ##A##. []
For the second part we need to show ##D_8## is not primitive on the set of vertices of a square. We label the vertices ##1, 2, 3, 4##. Let ##S \subseteq A## such that ##\vert S \vert = 2## or ##3##. If ##\vert S \vert = 3## and ##\sigma_1 = (1234)##, then ##\sigma_1(S) \cap S \neq \emptyset## and ##\sigma_1(S) \neq S##. So, suppose ##\vert S \vert = 2##. Then ##S = \lbrace a, b \rbrace## and there is ##c \not\in S##. Let ##\sigma_2 = (ac)##. Then ##\sigma_2(S) = \lbrace c, b \rbrace##. It follows ##S## is not a block. Since ##D_8 \subseteq S_4##, it follows the only blocks of ##D_8## acting on ##A## are the trivial ones, and so ##D_8## is primitive on ##A##.
Where did I go wrong in the second part?
fishturtle1 said:
Homework Statement:: Let ##G## be a transitive permutation group on the finite set ##A##. A block is a nonempty subset of ##B## of ##A## such that for all ##\rho \in G## either ##\rho(B) = B## or ##\rho(B) \cap B = \emptyset##. (here ##\rho(B) = \lbrace \rho(b) : b \in B \rbrace##).
Homework Equations:: .
A possible problem I see is the following:
How are you sure that ##\sigma_2\in D_8##? Not every transposition of ##S_4## is in ##D_8## (because ##S_4## is generated by all its transpositions).
Likes fishturtle1
Thanks!
Consider the square with vertices ##a = (0,1), b = (1, 1), c = (1,0), d = (0,0)##. Let ##S = \lbrace a, c \rbrace##. Observe,
##(abcd)\cdot S = (abcd)^3\cdot S = (ab)(dc)\cdot S = (ad)(bc)\cdot S = \lbrace b, d \rbrace##
and
##1\cdot S = (abcd)^2 \cdot S = (ac) \cdot S = bd\cdot S = S##.
This shows that for all ##\sigma \in D_4##, we have ##\sigma(S) = S## or ##\sigma(S) \cap S = \emptyset##. This means that ##S## is a nontrivial block. So ##D_4## is not primitive on ##\lbrace a, b, c, d \rbrace##. []
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
