H2O2 35% on Al 5083 at 150° gives 'limescale'
  • Thread starter Thread starter TomD1
    Heater
The discussion revolves around the formation of a substance described as "limescale" in a heater made of Aluminum 5083 used for heating hydrogen peroxide (H2O2) at 150°C for disinfecting plastic bottles. Participants explore potential causes of this deposit, including chemical reactions, water chemistry, and material properties.
  • One participant suggests that the presence of hard water may contribute to the formation of deposits, speculating on the dilution of peroxide with water.
  • Another participant raises the possibility of corrosion or deposition occurring near junctions due to temperature changes or electrochemical reactions between different materials.
  • A different viewpoint proposes that the deposits could be porous alumina or other compounds formed from cations in the water, emphasizing the importance of using demineralized water to prevent such issues.
  • Concerns are raised about the solubility of materials being temperature-dependent, questioning the inlet temperature of the peroxide solution.
  • One participant hypothesizes that the deposits could be Al2O3, suggesting that its growth is facilitated by the presence of liquid H2O2, which could explain the localized formation at the beginning of the heater.
  • Another participant questions the implications of Al2O3 formation, noting that it should lead to pitting or material loss in the aluminum substrate.
  • A participant seeks clarification on the nature of the deposits, asking whether they are chalky or hard, which could indicate different underlying causes.
Participants express various hypotheses regarding the nature and cause of the deposits, with no consensus reached on a single explanation. Multiple competing views remain regarding the chemical and physical processes involved.
Participants mention factors such as water chemistry, temperature effects, and material interactions, but do not resolve the implications of these factors or their specific contributions to the observed phenomenon.
TomD1
Hi,
In our production line we are heating h2o2 in a heater made of Alu 5083 to 150° for the disinfection of plastic bottles. After 6 months we needed to revise and clean our heater due to some sort of "limescale" formation. It only occurs at the beginning of the heater (I guess before evaporation).
Can someone help me figur out what this is?
Thanks in advance!
I'm guessing that you're diluting the peroxide with water. I'm also guessing that water is 'hard.'
When I see corrosion or deposition close to a junction, I suspect a step change in temperature, or an electrochemical reaction of the electrolyte, between the heater material and the feedline material.
As with the two previous posts, I was thinking that the oxide looks like porous alumina, but it could also may involve whatever cations are present in the water. Ideally one would be using demineralized water with little Mg, Ca, Si, which could cause formation of MgO, CaO, SiO2, among others. Porosity/cracking of the oxide reduces/compromises the protective/passive nature.
Besides water chemistry, the other issue is the solubility, a function of temperature. What is the inlet temperature of the peroxide solution?
Thermal cycling could be another issue, related to the other two factors. Oxides of metals and the metals tend to have differences in thermal expansion. If the thermal expansion of hte metal is greater than the oxide, then thermal cycling can cause microcracking of the protective oxide.
Thanks for the response!
The inlet temperature is around 20 degrees.
My view is that it could be Al2O3. Aluminium has a small layer of Al2O3 by contact with air. It can only occur with h2o2 in liquid phase, which is what would explain why it’s only at the beginning of the heater. By corrosion and a strong oxidation with h2o2, Al2O3 will keep on growing.
What do you think?
If it's Al2O3, there should be serious pitting / material loss on the your aluminum substrate.
TomD1 said:
Hi,
Thanks in advance!
Is it more of a chalky powder, or is it a hard, somewhat tough deposit? If it’s the latter, I’m inclined towards it being hard water deposits. If it’s the former, accompanied by pitting of the aluminum part, it’s corrosion of the part.
  • · Replies 59 ·
12K
9K
