Half life and activation energy
15 replies · 12K views
Hemolymph
I have two questions that I just don't even know where to start
The activation energy for the reaction CH3CO CH3 + CO is 71 kJ/mol. How many times greater is
the rate constant for this reaction at 170°C than at 150°C?
A) 0.40 B) 1.1 C) 2.5 D) 4.0 E) 5.0
and
A certain reaction A products is second order in A. If this reaction is 10.% complete after 20. s, how
long would it take for the reaction to be 90.% complete?
A) 180 s B) 1600 s C) 440 s D) 18,000 s E) 540 s
I know the second one is a second order reaction rate which has
1/[A]=1/[A_0]+kt
Borek said:
Have you heard about Arrhenius equation?
I can't see how I can apply the Arrhenius equation if I don't have any activation energies
Activation energy is given in the problem statement.
You will have to derive an equation using the Arrhenius equation to relate the rate constants. Take logarithm on both the sides of Arrhenius equation. Let the rate constant at temperature T1 be k1 and at temperature T2, let the rate constant be k2. You get the two equations:
[tex]k_1=Ae^{-E_a/RT_1}[/tex]
[tex]k_2=Ae^{-E_a/RT_2}[/tex]
Take logarithm on both the sides of the equation and subtract the equations you get.
ln(k1/k2)=Ea/R(1/t_2)-(1/t_1)?
Yes, that's right if you mean ln(k1/k2)=Ea/R((1/t_2)-(1/t_1)). (Take care of parentheses. :smile:)
ok so I did
ln(Rate 2/rate1)=71/.008314-((1/423)-(1/443))
got .911452
took e^.911452 = 2.5 so 2.5 times greater is rate 2 to rate 1
Hemolymph said:
ok so I did
got .911452
I haven't checked the calculations but your result matches with one of the options so I guess it is correct.
Hemolymph said:
Do you know how i could tackle the second one ?
You do have posted an equation in the main post. Did you try applying it?
Would I just be able to just substitute the percentages in as if they were concentrations?
You can do that but the problem is you are not given the percentage of concentration left.
The percentage left after 20 seconds is 90% of the initial concentration. So substitute [A]=0.9[A0], assuming [A0] to be the initial concentration.
(1/.9)=1/.1+k(20 seconds)
I got k to be .005555
so If I find t i get
(1/.1)=(1/.9)+.005555(t)
9/.0055555=t
t=1600s
that look like the right path to get to the answer?
How you got 0.1? Did you assume the initial concentration [A0] to be 0.1 M? If so, [A] would be equal to 0.09 M, not 0.9 M.
oh i did it wrong then i just assumed it was .1 because 10%=.1
same for 90% being .9
