Half Life for a second order reaction
1 reply · 20K views · last reply
preet
Slide text: oxidation of Fe2+ by O2 with differential rate law -d[Fe2+]/dt = k[Fe2+]^2 PO2; k = 3.7 x 10-3 L/(mol atm h) at 35 C, 0.5 M HClO4, PO2 = 0.2 atm; asks days for Fe2+ to drop from 0.10 M to 0.01 M.
HalfLife = 1 / k*[A]i
where k is the rate constant and [A]i is the initial concentration of a reactant A.
I don't have enough information to attempt this problem. I don't know what to do with the partial pressure of O2 (is it part of the reactants?) If it is, then does the reaction become third-order?
I also don't see the point of having HClO4 in this problem... does it change anything?
By using the given values of k and [Fe] and plugging into the equation, you get 2702.7 atm hours... I think this is wrong because I didnt use the partial pressure of O2 at all...
One final thing, the units by just using the half life equation give atm*hours... and if you divide by the pressure you get the correct unit, just hours. Is this the correct thing to do (the result is 13 513 hours)...
I just want to know whether I'm in the right direction.
Thanks
Preet
  • Text problem: oxidation of Fe2+ by O2 with rate law -d[Fe2+]/dt = k[Fe2+]^2 P_O2, k = 3.7 x 10^-3 L/(mol atm h) at 35 C in 0.5 M HClO4, P_O2 = 0.2 atm, asking for days for Fe2+ to drop from 0.10 M to 0.01 M.
Fe2+ does react with HClO4, assuming you can ignore the formation
of Fe(OH)2, you need to incorporate the rate dyanmics of this reaction and that of the Fe2+ reacting with oxygen gas. You need to put everything in terms of how the Fe2+ is depleted.
