Half Wave Antenna Vector Potential Calculation?
  • Thread starter stunner5000pt
    Antenna Wave
1 reply · 3K views · last reply
stunner5000pt
Vector Potential
Consider two half wave antennas each ahving current
[tex]I(z,t)=\hat{z} I_{0}\cos\omega t\sin k(\frac{d}{2}-|z|)[/tex]
where [itex]k=\omega/c[/itex]
Each antenna has length d and points in the z direction. Antenna 1 is at [itex](\Delta/2,0,0)[/itex] and antenna two is at [itex](-\Delta/2,0,0)[/itex]
a) Find the vector potential A
b) Find the electric and magnetic field
c) Find [tex]dP/d\Omega[/tex]
d) Evalute [tex]dP/d\Omega[/tex] in the X Y plane when the antenna is seaparated by a distance lambda/2. Along what direction is the radiation preferentialy propagated?
In CGS units so...
[tex]\vec{A}(\vec{r},t)=\frac{1}{c}\int \frac{\vec{J}(\vec{r},t_{r})}{|\vec{r}-\vec{r'}|} d\tau[/tex]
So we need the current as a function of z' and the retarded time
[tex]I(z,t)=\hat{z} I_{0}\cos\omega (t-\frac{\mathcal{R}}{c})\sin k(\frac{d}{2}-|z|)[/tex]
where [tex]\mathcal{R}=\sqrt{z'^2+r^2-2z'r\cos\theta}[/tex]
since we want the fields far away (radiation zone), expand
[tex]\mathcal{R}\approx r\left(1-\frac{z'}{r}\cos\theta[/tex]
so then
[tex]\cos\omega (t-\frac{\mathcal{R}}{c})\approx\cos\omega\left(t-\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)\right)[/tex]
[tex]\cos\omega (t-\frac{\mathcal{R}}{c})\approx\cos\omega t \cos\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)+\sin\omega t\sin\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)[/tex]
So then A is calculated like this? make the approximation that [tex]\mathcal{R}\approx r[/tex]
[tex]\vec{A} = \hat{z}\frac{I_{0}}{rc}\int \sin k\left(\frac{d}{2}-|z|\right)\left(\cos\omega (t-\frac{\mathcal{R}}{c})\left(\cos\omega t \cos\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)+\sin\omega t\sin\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)\right) dz'[/tex]
Ok since there are two antennas how should the integration be performed...
should i do for each antenna separately? That is integrate one of them from [itex]\Delta[/itex] to [itex]\Delta+\frac{d}{2}[/itex] and one of them from [itex]\Delta[/itex] to [itex]\Delta-\frac{d}{2}[/itex] ?? And then add the two results?
Thanks for your help!
Since it is a radiation problem, I think you are allowed to assume r>>r' and
kr>>1, which greatly simplifies the problem.
