Hard Momentum Conservation Impact Problem
The discussion focuses on solving a physics problem involving two identical charged particles, each with a charge of 0.1 mC and mass of 10 mg, projected at a speed of 104 m/s along parallel lines. The minimum distance between the particles is 12 cm, and the participants emphasize the use of linear momentum conservation and angular momentum conservation to analyze the system. Key insights include the importance of the center of mass for angular momentum calculations and the relationship between kinetic energy and potential energy at the point of closest approach.
  • Understanding of linear momentum conservation principles
  • Familiarity with angular momentum and its calculation
  • Knowledge of electrostatics, particularly Coulomb's law
  • Basic concepts of energy conservation in physics
  • Study the concept of "impact parameter" in collision theory
  • Learn how to apply conservation laws in multi-particle systems
  • Explore the relationship between kinetic energy and potential energy in electrostatic interactions
  • Investigate the mathematical formulation of angular momentum in polar coordinates
Students and educators in physics, particularly those focusing on classical mechanics, electrostatics, and conservation laws. This discussion is beneficial for anyone tackling problems involving charged particles and their interactions.
Ayesha02
Two identical charged particles each carrying charge q = 0.1 mC and of mass m = 10mg are projected along two parallel lines separated by a distance l, with equal speed V0= 104 m/s in opposite directions. In the beginning electrostatic interaction between the charges can be ignored due to a large distance between them. The minimum distance between the particles is found to be 12 cm. The value of l is equal to
Linear momentum conservation
I believe momentum conservation is to be used in this sum since there's no external force, but I am not sure how to write the equation.
Can someone please help me out:)
Ayesha02 said:
Homework Statement:: Two identical charged particles each carrying charge q = 0.1 mC and of mass m = 10mg are projected along two parallel lines separated by a distance l, with equal speed V0= 104 m/s in opposite directions. In the beginning electrostatic interaction between the charges can be ignored due to a large distance between them. The minimum distance between the particles is found to be 12 cm. The value of l is equal to
Relevant Equations:: Linear momentum conservation
Have you studied something relevant leading up to this? Do you know what the "impact parameter" is?
In any case, conservation of energy and angular momentum are your friends here.
not exactly the term impact parameter, but yeah I've done impulse- idk if that's the same..
Moving on, coming to angular momentum I am not quite sure how to write the equation- as in about what point am i conserving angular momentum? If possible, could you write the equation?
Try angular momentum about the centre of mass.
It's a different concept.
Like @PeroK said, write the initial angular momentum, and the final angular momentum (what does the path of the particle look like when they're really far apart again).
What sort of shape do you get? What constraints can you put on the final velocities?
Okay so i gather final angular momentum should be 2(m*v*6)
is that right?
Im still not able to figure out initial angular momentum
is that right?
an afterthought:
why not conserve linear momentum?
Ayesha02 said:
an afterthought:
Because you have a spherically symmetric potential. Working with polar coordinates ##r, \phi## and angular momentum is going to be easier.
Initial angular momentum is just ##\pm mvl/2##, isn't it?
ohh yaa!
Another thing- why don't the bodies change velocity from the initial to the final?
Ayesha02 said:
ohh yaa!
If by final you mean when they're really far apart again, then what's their potential energy? Is any external work done?
Nah!
the final situation, as mentioned in the question, is when they're at min distance
Ayesha02 said:
Nah!
So do they have the same kinetic energy as they do initially?
Exactly my doubt!
why do they have the same KE finally as well?
@PeroK could you help us?
Ayesha02 said:
Exactly my doubt!
Um no it was a question but okay. Can it have the same kinetic energy?
Ayesha02 said:
Nah!
It's that point that you need to analyse. Apart from minimum separation, what else can you say about the motion at that point? It's implied by minimum separation.
They can't go any further right, so shouldn't velocity be zero at that point?
No. That's only for a head-on collision ##l = 0##. If ##l \ne 0## then neither particle stops.
archaic said:
How so? I might have interpreted ##l## wrongly, but, even if it's the distance separating the charges, you can't have the angle between your origin and momentum be equal to ##\pi/2## for both charges at the same time..?
That's just the angular momentum of one particle at the point where they're separated at infinity.
Ohh alright then
Here we go again. It's a) homework helping someone else and b) sorting out your problems too!
This isn't your homework!
  • Sad
I'm going to step back now because I think I'm interrupting @PeroK's flow and my phone's going slightly mad with notifications.
All I will say is that you can solve the problem by applying the two conservation laws he mentioned between the points where the two are separated at infinity, traveling along two parallel lines, and the point of closest approach. Don't miss out different types of energy!
Same answer to both... because of the symmetry, the total linear momentum of the system is zero. As a result, it doesn't matter what axis you use for the angular momentum of the system; they will all yield the same answer.
I would simply say it is mv0l.
By conservation of energy, what will the KE be when they are at separation x?
Yes dude got it thankyou:)
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 23 ·
