Harmonics Question; prove that v max of a mass on a spring is given by 2 pi f A
The maximum speed (Vmax) of a mass on a spring is definitively expressed by the formula Vmax = 2πfA, where f represents frequency and A denotes amplitude. This conclusion is derived from the principles of simple harmonic motion (SHM) and the relationship between angular frequency (ω) and frequency (f), specifically ω = 2πf. The derivation involves the kinetic and potential energy equations of the system, leading to the understanding that at maximum velocity, the displacement (x) is zero.
  • Understanding of simple harmonic motion (SHM)
  • Familiarity with the concepts of angular frequency (ω) and frequency (f)
  • Knowledge of kinetic and potential energy equations in oscillatory systems
  • Basic algebraic manipulation skills for rearranging equations
  • Study the derivation of the simple harmonic motion equations
  • Learn about the relationship between angular frequency and frequency in oscillatory systems
  • Explore the concepts of kinetic and potential energy in mechanical systems
  • Investigate the applications of SHM in real-world scenarios, such as pendulums and springs
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to explain the principles of simple harmonic motion and energy conservation in oscillatory systems.
lost_in_phys
The question is exactly this:
Prove that the maximum speed (Vmax) of a mass on a a spring is given by 2(pi)fA.
where f = frequency and A =Amplitude
We are given such formulas as:
f=[1 / 2(pi)]square_root (k /m) or
f=[1 / 2(pi)]square_root (a /-x)
the formula for total energy in a system (1/2*m*vsquared + 1/2*k*xsquared)
When I try to do it, I try to rearrange the formulas and get stuck in a giant maze of variables and such.
This question was asked before on this forum as part of another question but was never answered
Use energy equations!
What does k/m equals to?
Go back to the basics.
that doesn't really help me. Maybe mentioning which ones I should use would help, because I start to use some but they don't seem to get me where I want. It's like math class all over again with that darn unit with rearranging cos(x), sin(x), and tan(x), i hated that too.
nvm, i figured it out
can anyone elaborate on how he figured it out?
For SHM
v= \pm \omega \sqrt{A^2-x^2}
x is the displacement from the equilibrium position.At +A, you have max pe and 0 ke.
At -A you have max pe and 0 ke. At the equilibrium position you have 0pe and max ke (which means?)
im not really following because I've never seen that equation before; i understand the amplitude part where at equilibrium the mass has kinetic energy while before or after the equilibrium the mass will have potential energy.
The basic SHM eq'n: a=- \omega^2 x
a=\frac{dv}{dt}=v \frac{dv}{dx}
so that
v \frac{dv}{dx}= - \omega^2 x
and solve that, remembering that when x=A,v=0 and you'll arrive at the equation.
rock.freak667 said:
For SHM
oh okay so i read up on SHM and circular motion on the internet (not in my textbook) and it says that: Note that the in the SHM displacement equation is known as the angular frequency. It is related to the frequency (f) of the motion, and inversely related to the period (T):
\omega = 2 \pi f
so...
v= 2 \pi f \sqrt{A^2-x^2}
and since velocity is at a maximum that means that displacement is 0 so x = 0 and then:
v= 2 \pi f \sqrt{A^2-0}
v= 2 \pi f A^2
right? :confused:
I just don't really understand what \omega stands for?
Note:\sqrt{A^2}=A
\omega is the angular frequency i.e. the number of oscillations in 2 \pi seconds
oh yea i forgot to take that off, but thank you for all your help!
But if we want an answer without straying from the text (assuming you are using ILC's SPH4U funded by TVO), then we can go to Lesson 6, page 12.
Right at the top, it gives the equation T=2(pi)r/v
*If you know how to graph trig functions, or understand them even in the least, you know that the (r)adius is the same as the (A)mplitude
Thus: T= 2(pi)A/v
Isolating for v, we get: v=2(pi)A/T
But since T=1/f;
v=2(pi)Af
(v)oila
  • · Replies 29 ·
