Hashing Problem Homework: Generate Hash Function from Table
  • Thread starter Thread starter gruba
    Algorithm
The discussion revolves around generating a hash function from a table that outlines the dependencies of car parts in a production line. The table specifies which parts must be installed before others, and the goal is to determine a machine order that allows for uninterrupted manufacturing. A proposed solution indicates that the only valid order is 4, 2, 1, 3, 8, 7, 6, 5, while certain lists cause interruptions. Participants express confusion about the relationship between the hash function and the installation order, questioning how the order can be considered a function and what exactly is being hashed. The conversation highlights the need for clarity on the algorithm's purpose and the definition of the hash function in this context.
gruba
In a factory, machines are making cars (1-n) along the production line. One machine is making one part on the existing construction (part 1 is made by machine 1,...). Installation order of some parts is not important, but some parts have to be installed before others. Engineers have put together a dependence list for car parts as a table:
1 2
2 4
3 2,1
6 4,7
7 3,8
8 4,3,1
where the first column represents parts (1-8), and the second column represents preconditions for installment of each part. That is the list of parts (second column) whose installment must be done before the installment of current part (first column).
For each given list (second column), find the order of machines along the production line such that the manufacturing process of a car is done without interruptions, if such order exists. Also, find lists from the given table that give orders with interruptions.
Design an algorithm for this problem.
Show the final order of machines along the production line, if it exists.
-Hash functions
-Hash tables
For each part (1-8, first column) we have to find a hash function without collisions that satisfies the second column in the table (if possible).
This is obviously the reversed process from generating hash table from given hash function.
I have found that the only possible order of machines along with production line, such that there is no interruption in the process is:
4,2,1,3,8,7,6,5
Also, lists 4-7,4-3-1 are causing an interruption (collision) in a process.
Question: How can we generate hash function from hash table (reversed algorithm from standard, where hash function is given - create hash table)?
I do not understand how the problem of finding an algorithm for this has anything to do with hash functions. Can you explain what you mean by the hash function "satisfying" the second column?
Maybe I have misunderstood the problem. I think that for each given list (second column), the order of machines along the production line such that the manufacturing process of a car is done without interruptions, if such order exists, is a hash function. Sequence that I gave in the original post should be generated by some function, right?
gruba said:
the order of machines ... is a hash function
In what way can the order of a sequence be a function? A function of what? What are we hashing and what is the output?
